It is currently Fri Jul 18, 2025 6:41 pm
Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
 Trailer Mods for Guides and Shallow Water
Post Trailer Mods for Guides and Shallow Water
Two things about trailering.
Has anyone done anything to better help launch and retrieve boat in shallow water or with a landing that has very little angle to it. Maybe like rollers on the back after the bunks. Or any suggestions.
And the second, when retrieving the boat and putting it on the trailer, I want to have my side guides higher so I can put the trailer back in the water further. If I put the guilds under the water (just the last foot of them , even if you hit it straight on, it will sometimes blow to the side on the edge with the wind or in some cases current. Anyone modified their trailer in for that?
VooDoo--what you get when you leave your Voo outside all night long.
Sat Jul 13, 2013 9:17 pm
Post Re: Trailer Mods for Guides and Shallow Water
Teflon bunks or gatorglide, the trailer bunks don't even have to be in the water then...
Sun Jul 14, 2013 5:22 am
was this on unloading or loading or does it matter? You can load it up with the trailer that much out of the water?
My bunks are rubberized. I may have to try gator glide.
Sun Jul 14, 2013 5:26 am
RUBBERIZED???? Like truck bed liner type of shit?
Get new bunks with carpet and some GG on your hull.....
Sun Jul 14, 2013 5:27 am
Sun Jul 14, 2013 5:47 am
Yeah, get rid of that shit fast. Either take a grinder and buff it off the bunks and carpet over the bare wood, or get new bunks with carpet. Water will eventually get under that rubber and rot the wood so just carpeting over it as it is now wouldnt do yourself any favors.....
Sun Jul 14, 2013 5:58 am
Not sure what kind of trailer you have but the older ones have the pin you pull put and the trailer will tilt to help when you have none or a lil water..
17x54 Extreme Pushed By A Gtr 35 Stage 2 Done ByJamieB Baw!
Nut Up Or Shut Up
Sun Jul 14, 2013 6:05 am
Yeah, what Chaz said!
Also, Chaz, your deckboards will suffer the same fate as VD's trailer bunks.
Sun Jul 14, 2013 6:12 am
Nut Up Or Shut Up
Sun Jul 14, 2013 6:17 am
Yeah, I was talking about the crewboat. Mostly just trying to start some shit with you though. They look good painted, but they rot faster.
Sun Jul 14, 2013 6:37 am
Sun Jul 14, 2013 7:21 am
Sun Jul 14, 2013 8:33 am
The carpet wont trap the water like the rubber will. It can dry out between launchings.
Sun Jul 14, 2013 8:34 am
Ok it sure will eat through the bottom of ur boat though
Sun Jul 14, 2013 8:40 am
The best thing to do is put plastic over ur boards
Sun Jul 14, 2013 8:41 am
Silicone spray for your bunks cheap and easy fix
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
I use a second Hand winch attached to the post on the trailer with the line run through a snatch block chained to one of the beams on the rear of the trailer. Hook it up to the bow eye and it cranks the boat right off the trailer. Works well. I also used old fire hose on the bunks which helps a lot.
Sun Jul 14, 2013 10:54 am
Gator glide and u can push it off with one hand and mine is 18\60
Sun Jul 14, 2013 11:15 am
To the OP, regardless of tricks with your bunks, gator glide, etc. see if there is room for you to mount your leaf springs under the axle rather than them sitting on top. That will lower your entire trailer/boat height by roughly 4" which makes a big difference when launching shallow water or a not-so-steep decline.
Sun Jul 14, 2013 11:21 am
Sun Jul 14, 2013 11:28 am
^^This^^
Also you could make your own lowrider trailer with torsion spring spindles pretty easy.....
Just weld them on up high somewhere....
Sun Jul 14, 2013 11:37 am
The "lowering" of trailer is best option overall but be careful with a GTR and trailering bracket.
I've seen some leave my shop with low trailer or even too tall of hitch height and tell them I hope you don't go over a lot of dips or uneven roads because I can see the skeg scraping pavement.
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sun Jul 14, 2013 11:57 am
Thanks for all the replies, very helpful, lots to think about. Gator Glide will be something I will do in the fall, probably after I get through my busy season. And I may cover the bunks with silcone or the fire hose (where can you get some of that?) I like the second winch idea if I did not gator glide it soon, would take only a few minutes to install and not that much money.
On the tilting trailer, I do not have one of those. But that would be helpful.
Sun Jul 14, 2013 6:37 pm
Gator Glide is all you need to do. You will also then see the real benefits of GG. The trailer thing is just an added benefit. Trust me!
Sun Jul 14, 2013 7:07 pm
GG is slick for sure! First time I have been able to just drive my boat right up on trailer on a steep ramp. And boards were not in water. Had to get gf to hook hand winch up bc boat would not stay! Highly recommend!!
Sun Jul 14, 2013 7:15 pm
You don't need higher side guides ("drunk boards" is what I call them) just make them longer. I have 6' guides on my 17' boat and they don't go all the way to the transom. Always some of them out of the water.
17' CAT 5 with 37 GTR
Sun Jul 14, 2013 7:35 pm
I had my welder at work build some pipe guides for me last week. I like them way better than guide boards! I set them tight so the boat can't slide far side to side when I'm trailering it too. I made the steel pipes 2' tall and the PVC pipes that slide over them 4'. I'm going to cut the PVC down to 3' or less though because I never back the bunks in the water, due to the GG. I'll post a pic tomorrow if you'd like.
Sun Jul 14, 2013 7:47 pm
Sun Jul 14, 2013 8:12 pm
Sun Jul 14, 2013 8:17 pm
Coot, yes, post some photos, thanks.
Thanks to all that responded too.
Sun Jul 14, 2013 8:27 pm
Sun Jul 14, 2013 8:53 pm
1754GT 35GTR
Sun Jul 14, 2013 9:04 pm
B. MacDonald
Mon Jul 15, 2013 4:18 am
Not sure if this is what you're lookin for but I took a piece of square tubing that would slide into the main tongue of the trailer and selded the coupler on to it then I drilled holes for a pull pin through both the outside and inside tubing in a "pulling" position (coupler close to the end of the square tubing) and another hole in the inner tubing closer to the end. By doing this I am able to extend the tongue of the trailer by 10 ft or so if needed to get the boat out far enough to get into the water. Ill see if I have some photos to post later.
1436 Lowe
Mon Jul 15, 2013 8:42 am
i screwed UHMW to the bunks and i removed the 13 inch wheels an dput on 8 inch glof crt wheels
takes some effort but way easier getting on and off in the mud
a friend of mine did the same but he installed rollers on top of the bunks and wow he just simply lines up hits the gas in reverse and hits the breaks and presto in the water and when done he has a winch on his trailer he just pulls it back up with
and im talking a twin screw 2060 prodrive not alittle boat
Mon Jul 15, 2013 9:21 am
Mon Jul 15, 2013 1:28 pm
Thanks posting that Coot, that's what I'm gonna do
Mon Jul 15, 2013 1:53 pm
Thanks Coot for posting photos. I did not see this until now, while I was using search for something else.
I looked at the bunks, I thought they looked like rubber, but after looking at them closer they are plastic that sort of look like rubber. I had to thump them to make sure.
I also saw a trailer that has some bunk extension on the back. They looked like covered aluminum on edge rather than flat that were angled at what looked like a 45 degree right behind the bunks. So if you were in a situation where there was no or not much landing incline it would just angle it up tot he bunks. Looked like they were only about a foot long each. I think there were 4 of them.
Wed Jul 24, 2013 8:19 am
Wed Jul 24, 2013 9:19 am
Wed Jul 24, 2013 9:58 am
Users browsing this forum: No registered users and 129 guests
