It is currently Tue Jul 15, 2025 9:17 am
Reply to topic  [ 31 posts ]
 building a cooler radio need help.
Post building a cooler radio need help.
Im building a cooler radio and I need help on figuring out what size amp I need. Does the amp have to match the wattage of the speakers or the speakers match the wattage of the amp.
I sall some good videos on youtube on how to but I seen this guy built one with a sub what kinda amp would I need if I was gonna put a small 8 inch sub with two kicker 6x9's
http://www.youtube.com/watch?v=GdvucG4NVYw
the post is not about the song in the video just the build.
Sat Feb 22, 2014 6:41 pm
Post Re: building a cooler radio need help.
i was reccomended a 300w amp when i was building my audio pipe i have 2 6x9 3way pioneer speakers in it, but i didnt put an amp bc i already had the pipe back on.
my build-
viewtopic.php?f=7&t=50449
Sat Feb 22, 2014 6:59 pm
I think it was big rich with the best I've seen
http://www.gatorglide.com/
gatorheads@comcast.net
Sat Feb 22, 2014 7:20 pm
so you don't need an amp im guessing the amp cant be 2000 watts and your speakers be 200.
Sat Feb 22, 2014 7:23 pm
Partyinmycooler.com
1744 WC Custom
25 GTR
Sat Feb 22, 2014 7:24 pm
Ive got a 300 rockford fosgate pushin 4 6 1/2 wet sounds
4500 black death with a little more in it strapped to a 1848 wc custom
Sat Feb 22, 2014 7:26 pm
are the number of channels the amount of ports for speakers to hook up ie 2 channels only two speakers four channels four speakers?
Sat Feb 22, 2014 7:32 pm
You want the rms ratings on the amp and speakers to be similar, and want the gains set properly. Setup properly, equipment will last a loooooong time. If the radio has high voltage outputs a quality 200 watt amp is capable of making double or triple it's power rating, it just does it with horrible inefficiency. Loads of distortion and will draw way more current than it should. That isn't good for any of the equipment. Stick to quality equipment, try to match rms ratings, and set the gains properly (the gain is NOT a volume knob), and it will sound good and last a long time.
Sat Feb 22, 2014 7:34 pm
Sat Feb 22, 2014 7:37 pm
I wasn't going to use a radio... just a rca cord pluged into the amp to plug into my iphone so id just have an amp, speakers, battery, and rca aux cord. is that a horrible idea? this is where I got that idea
http://www.youtube.com/watch?v=vkdqdJ-N2Yo
Sat Feb 22, 2014 7:41 pm
Lot's of people do it, but I'm not a fan of it. I much prefer to have a good source unit inline. Hooking an ipod straight to the amp makes it very hard to set it the way it's supposed to be set. It can be done right, but I've never seen one that someone else did set anywhere close to how it should be. :lol: Most I've seen they had like every damn knob on the amp turned all the way up and used the ipod to change volume. Gains should be set to match input voltage. It can be done right, but usually it's not.
Sat Feb 22, 2014 7:48 pm
1854 Extreme CC 35 GTR
RTR!!!
Sat Feb 22, 2014 8:57 pm
RTR!!!
Sat Feb 22, 2014 9:04 pm
I've got it all hooked up and it plays but only half of the song the lead voice doesn't show up or bass just background and acoustic whats the issue is it the amp or the fact that I just go straight from my iPhone into the amp?
Mon Mar 03, 2014 11:23 am
Sounds like you have a crossover turned on. Set the cross over to off, or full range.
Mon Mar 03, 2014 11:26 am
That or you're not making a solid connection, try a different cable if turning off the crossover isn't the fix.
Mon Mar 03, 2014 11:28 am
What's a low pass cross over all I have is gain reverse polarity and speaker or rca. The only thing I ain't tried is to push the reverse polarity button
May not even have a crossover. I don't use pyle products. Reverse polarity shouldn't make much of a difference as long as both speakers are hooked up the same way. You don't really want it set in the reverse mode though.
Try a different cable (and different source if you can), if that don't fix it, it's probably just the amp.
Mon Mar 03, 2014 11:32 am
The amps just to weak?
Mon Mar 03, 2014 11:40 am
It's just junk. Probably don't work like it's supposed to.
But like I said, try a different cable and source. A broken/pinched cable or cable not making a solid connection can do some weird stuff with the signal. Do you have something else you can plug the cable into to see if the cable/phone is working properly?
That thing you have isn't really an amp either, I mean it is, but it's basically the little chip that comes inside of a radio, so you would have been just the same buying a junk pyle headunit. You're lucky if you're getting 10 watts per channel clean, even when it's working properly...
Mon Mar 03, 2014 11:48 am
I tried my ol ladies phone to and wiggled the wires ima try a different amp from Walmart.
Mon Mar 03, 2014 12:14 pm
Just buy a name brand radio and be done with it. (kenwood, pioneer, jvc, sony, apline, etc, not dual, pyle, boss, etc.) The little amps you're looking at won't put out any more power and aren't likely to have a very long lifespan. For 70 bucks you can get a decent radio, that will last a long time, give you the option to listen to the radio, cd's, or plug your phone in. Step up your budget just a hair, and you can run the signal via bluetooth from your phone, and not have to take it out of a dry box all day. You can always add a decent amp to your radio down the line if you need it, but the products you're looking at aren't going to give you any more power than just a plain jane radio.
Mon Mar 03, 2014 12:24 pm
It was the amp I got a kicker in there now and it's loud as fuck now the radio and the amp were about the same prices
Mon Mar 03, 2014 1:32 pm
:lol:, went from can't understand it to TURN IT DOWN :lol:
Mon Mar 03, 2014 1:40 pm
Fuck ya bitches and hoes blue
Mon Mar 03, 2014 10:00 pm
[attachment=-1]uploadfromtaptalk1395100025179.jpg[/attachment]
Here ya go
Sent from my SM-N900V using Tapatalk
Stage 2 Mini 23 chasing a 1642 Prodigy
Mon Mar 17, 2014 5:47 pm
Mon Mar 17, 2014 5:53 pm
Damn.....that was a $500 cooler.
Mon Mar 17, 2014 9:17 pm
Mon Mar 17, 2014 9:39 pm
bet it wont tip over easy though
Tue Mar 18, 2014 12:39 pm
That yeti radio has to be the biggest waste of money I ever seen . Wow 500 dollar ice chest ,100 dollars worth of audio lol
17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
Sat Mar 22, 2014 7:11 pm
Users browsing this forum: No registered users and 100 guests
