It is currently Fri Jun 27, 2025 5:04 am
[ 8 posts ] |
minuki carb on pro drive add on
old drake
got parts for pro drive from performance brothers out of houston area a while back. they are no longer in business for a while. any one know what the discription of what carbs they used. from what i can see on web it is a HSR model with a side cold start pull out and throttle not straight off the top. not sure what size think 33m or 34mm. need some parts for it. any thoughts were to look for parts? thanks
Mon Nov 16, 2015 9:34 am |
Russ
 Re: minuki carb on pro drive add on
What size engine? And Google is your friend. As is the search function on here.
Mon Nov 16, 2015 9:51 am |
old drake
need to make correction it is a mikuni and it was the performance twins out of houston and it goes on a 36 hp pro drive thanks
Tue Nov 17, 2015 7:12 am |
Russ
It won't be a 33 or 34mm. The hsr comes in 42, 45, and 48mm. In all likelihood, it's the 42mm, but they all use the same jets and parts.
Tue Nov 17, 2015 7:35 am |
brickgw
Yep mikuni hsr42, you should be able to order just about anything you need for it from jetsrus.com
Tue Nov 17, 2015 8:38 am |
old drake
great I knew you guys would have it thanks
Tue Nov 17, 2015 9:58 am |
cb5331
Tue Nov 17, 2015 10:28 am |
Russ
For a stock motor, yes. It's on my father's motor now. It really hated mine.
Tue Nov 17, 2015 10:46 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 230 guests |
