It is currently Fri Jun 27, 2025 12:31 am
Reply to topic  [ 8 posts ]
 minuki carb on pro drive add on
Post minuki carb on pro drive add on
got parts for pro drive from performance brothers out of houston area a while back. they are no longer in business for a while. any one know what the discription of what carbs they used. from what i can see on web it is a HSR model with a side cold start pull out and throttle not straight off the top. not sure what size think 33m or 34mm. need some parts for it. any thoughts were to look for parts? thanks
Mon Nov 16, 2015 9:34 am
Post Re: minuki carb on pro drive add on
What size engine? And Google is your friend. As is the search function on here.
Mon Nov 16, 2015 9:51 am
need to make correction it is a mikuni and it was the performance twins out of houston and it goes on a 36 hp pro drive thanks
Tue Nov 17, 2015 7:12 am
It won't be a 33 or 34mm. The hsr comes in 42, 45, and 48mm. In all likelihood, it's the 42mm, but they all use the same jets and parts.
Tue Nov 17, 2015 7:35 am
Yep mikuni hsr42, you should be able to order just about anything you need for it from jetsrus.com
Tue Nov 17, 2015 8:38 am
great I knew you guys would have it thanks
Tue Nov 17, 2015 9:58 am
Tue Nov 17, 2015 10:28 am
For a stock motor, yes. It's on my father's motor now. It really hated mine.
Tue Nov 17, 2015 10:46 am
Users browsing this forum: No registered users and 182 guests
