It is currently Fri Dec 19, 2025 3:48 pm
[ 7 posts ] |
Badrhino
Joined: Sat Dec 06, 2014 2:14 am Posts: 33 Location: Pine Prarie LA
 37 GTR Tiller
Hey guys been running my 37GTR just curious is it common for it to try and pin u in the seat while making left hand turns. Turning to the right i have no problems. This is a 2015 i dont think u can adjust the torque tab please correct me if wrong.
_________________ 2015 GTR 37 on xpress 16-51HD
| Wed Dec 02, 2015 8:00 pm |
craig
 Re: 37 GTR Tiller
Yes, it's common.
If it's a cast lower unit, no you cannot adjust. If it's a machined lower you can.
Does it push towards you really bad when running straight? If so you may need to mount the engine offset an inch or two.
| Wed Dec 02, 2015 8:58 pm |
Badrhino
 Re: 37 GTR Tiller
No driving straight it's fine. Just turning that one direction.
| Wed Dec 02, 2015 9:07 pm |
craig
 Re: 37 GTR Tiller
Then you're good.
You'll get used to it. When making turns, stand up and use your body to help support the tiller.
| Wed Dec 02, 2015 9:12 pm |
SirBacon
 Re: 37 GTR Tiller
Mess with how your loading the boat. Mine will do the same if I don't distribute the weight right. For whatever reason it seems to like being right side heavy. It drives me nuts though. If it's loaded even just a little off, I fight the tiller even going straight. I need to look into maybe shifting the motor and see if it will correct.
| Thu Dec 03, 2015 11:58 pm |
Bernhard1
 Re: 37 GTR Tiller
I have a 2012 35 GTR and i have something similar going on. When going straight and i look back at the motor. It almost looks like my tiller is slightly pointed to the right like im taking a mild left hand turn. Also, i've notice that the rooster tail the motor throws is more on one side than the other... Any ideas?
| Tue Dec 08, 2015 11:13 am |
DOT3
 Re: 37 GTR Tiller
| Tue Dec 08, 2015 6:22 pm |
[ 7 posts ] |
