It is currently Sat Dec 20, 2025 10:32 am
Reply to topic  [ 7 posts ]
 37 GTR Tiller
Post 37 GTR Tiller
Hey guys been running my 37GTR just curious is it common for it to try and pin u in the seat while making left hand turns. Turning to the right i have no problems. This is a 2015 i dont think u can adjust the torque tab please correct me if wrong.
2015 GTR 37 on xpress 16-51HD
Wed Dec 02, 2015 8:00 pm
Post Re: 37 GTR Tiller
Yes, it's common.
If it's a cast lower unit, no you cannot adjust. If it's a machined lower you can.
Does it push towards you really bad when running straight? If so you may need to mount the engine offset an inch or two.
Wed Dec 02, 2015 8:58 pm
No driving straight it's fine. Just turning that one direction.
Wed Dec 02, 2015 9:07 pm
Then you're good.
You'll get used to it. When making turns, stand up and use your body to help support the tiller.
Wed Dec 02, 2015 9:12 pm
Mess with how your loading the boat. Mine will do the same if I don't distribute the weight right. For whatever reason it seems to like being right side heavy. It drives me nuts though. If it's loaded even just a little off, I fight the tiller even going straight. I need to look into maybe shifting the motor and see if it will correct.
Thu Dec 03, 2015 11:58 pm
I have a 2012 35 GTR and i have something similar going on. When going straight and i look back at the motor. It almost looks like my tiller is slightly pointed to the right like im taking a mild left hand turn. Also, i've notice that the rooster tail the motor throws is more on one side than the other... Any ideas?
Tue Dec 08, 2015 11:13 am
Tue Dec 08, 2015 6:22 pm
