It is currently Sun Dec 21, 2025 12:54 pm
Reply to topic  [ 7 posts ]
 Carb Spacer
Post Carb Spacer
I know back in the day we would put a 1" Spacer under the carb on our hotrods to give it a "tunnel ram" effect and get a little more torque. Has anybody tried this on these motors and if so what was the outcome?
Wed Sep 30, 2009 10:22 pm
Post Re: Carb Spacer
Haven't tried it yet, but have contemplated throwing a spacer behind the S&S on my motor. In general, longer intake runners produce more power at lower rpms, just as longer headpipes help produce more torque than short ones.
Thu Oct 01, 2009 4:12 am
Thu Oct 01, 2009 6:08 am
Generally speaking if fuel and air passes trhough the carb/ throttle body it will help. If just air goes throught the throttle body its useless.
Basically in a small block Chevrolet with a carb or a TBI motor they will boost some TQ due to having a little more room for the air and fuel to mix for optimium atomization.
Now on a vortec injected motor and the new LS style you are wasting your time.
With that said it can be worth a shot if the spacer can be had for cheap to try it.
Thu Oct 01, 2009 8:15 am
Thu Oct 01, 2009 5:10 pm
ran a carb spacer on my old rig with the stage one!! When Hoyt built mine and a friends he built them together and they had about the same power and rpm range. his didn't have a spacer!! Just spend the money and get a set of heads done deal!! CHEAP AZZ :lol:
17x48 extreme stage 2 GTR
Thu Oct 01, 2009 5:44 pm
Thu Oct 01, 2009 7:42 pm
