It is currently Tue Jul 15, 2025 4:34 am
Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
 Gator gliding my boat
Post Re: Gator gliding my boat
Don't know not much of a fan of red. Might make it hard to hide. You might have to do more coats of the glide to hide it.
Mon Mar 17, 2014 7:42 pm
Ok that is what I was thinking. I'm going with the same thing you did.
1754 prodigy- stage 2 GTR
Mon Mar 17, 2014 7:46 pm
Good deal, and when everyone said frog was good to work with they were right. He will answer your call and take the time to go out his way to help you.
Mon Mar 17, 2014 7:52 pm
How long are you guys waiting in between coats? Should it fully cure each time, in between coats, for better results? Thought I saw dry to the touch in two hours. So would it bond better if waiting 2 hrs each coat? (For the base and g2 both)
Mon Mar 17, 2014 8:46 pm
Depends , on temps. , humidity , but definitely not. 2 hours , mine was dry to the touch within 15 mins or so , I started port side bow to stern , then starboard stern to bow , by the time I got to starboard bow the port side was dry to touch. , I essentially just made laps till I had 5 thin , thin coats on. . I let it cure / dry for about. 2 hours ( when I couldn't dent it with a fingernail ) before setting back down on trailer. , let it sit several days dry to completely cure before running in water. .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Mon Mar 17, 2014 8:54 pm
Mon Mar 17, 2014 9:10 pm
Just got my order in! Thanks for the info!
Tue Mar 18, 2014 7:04 pm
Tue Mar 18, 2014 7:10 pm
So after u apply the base and it cures do u need to sand again before applying G2-G4..?
18/60 Prodive With Dual 37 EFI Prodrives Gen III...
Tue Mar 18, 2014 7:58 pm
Yes with either a scotch-brite pad or 400 grit.
Tue Mar 18, 2014 8:06 pm
Users browsing this forum: No registered users and 100 guests
