It is currently Wed Jul 02, 2025 12:12 am
Reply to topic  [ 25 posts ]
 access hatches
Post access hatches
Tried the search couldn't fine what I was looking for.
Anyone add a access hatch to their bench seat for more storage? What brand, type, did you like it?
MB 35hp LT/1754 Grizzly
Thu Aug 21, 2014 6:34 pm
Post Re: access hatches
What are you type looking for?
Thu Aug 21, 2014 7:50 pm
Cut and drop in kind. Just looking for ideas.
Thu Aug 21, 2014 7:59 pm
man I had a pic of one I just put in one of my boats...if I can find the name brand ill post it up for ya....I got the dealership I bought my bay boat from to send me one...west marine has some you can look at and TH Marine has some also...check amazon for marine hatch's
Thu Aug 21, 2014 8:17 pm
I got one off eBay I don't remember the exact dimensions but it's around 10x14 I think I'll try adding a pictureImageUploadedByTapatalk1408737606.807073.jpgImageUploadedByTapatalk1408737630.742186.jpgImageUploadedByTapatalk1408737649.373730.jpg
Fri Aug 22, 2014 2:00 pm
do a search on ebay. search for boat hatch. a ton come up.
believe the ones I have used in past are the tempress ones
Fri Aug 22, 2014 4:28 pm
I put a tempress hatch in the middle seat of all my little Jon boats. They do the job and are worth their weight in gold for stowing clutter type chit
Fri Aug 22, 2014 4:35 pm
Any one see any aluminum hatches anywhere?
How do the plastic ones hold up if standing on them?
Fri Aug 22, 2014 4:54 pm
Cabelas has the aluminum ones
1848 Uncle J and 37 EFI GTR
Fri Aug 22, 2014 5:04 pm
Fri Aug 22, 2014 5:07 pm
Fri Aug 22, 2014 5:24 pm
my podna is 265lbs and walks on mine
Fri Aug 22, 2014 5:58 pm
I like the Cabela's one, looks like it would be more flush. Thanks everyone for the input.
Fri Aug 22, 2014 7:45 pm
Tempress. Mine worked fine standing on it but it was a relatively smaller hatch. Was water tight as well.
Sat Aug 23, 2014 7:00 am
The hatches from Cabela's are tough. I put the large one in the small front deck on my boat. It get's walked on all the time and is built for it. They are spendy but worth every penny in my opinion. I'll be adding a couple of the medium sized ones as well. I searched for a long time online and they seem to be the toughest ones available.
Backwater Swomp 23 / Lowe L1448M
Sun Aug 24, 2014 12:12 pm
Went with the Cabelas one. Cut the hole and started taking foam out of bench, what a pain in the *ss! Have another question, does the foam give needed support to the bench itself? As I started taking foam out, seemed that the bench gave a little in the middle. Can I take all the foam out?
Anyone done this to a Tracker Grizzly before?
Tue Sep 02, 2014 12:38 pm
Pulled all the foam out of my old boat you'll be ok it'll stiffen up when you put the hatch in, but if you want leave some around the edges as padding so stuff doesn't beat around.
Sent from the company's iPad while at work
Dont criticize a farmer with your mouth full
Tue Sep 02, 2014 4:42 pm
^ and have fun pulling that foam out. It's miserable
Wed Sep 03, 2014 7:28 am
Piece of flat bar heated up acts like a hot knife thru butter makes it easy
Wed Sep 03, 2014 8:01 am
Thanks guys. Will try the hot flat bar when my back decides its not still mad at me.
Thu Sep 04, 2014 4:12 pm
A pressure washer works with a turbo tip but it makes a mess
Thu Sep 04, 2014 5:18 pm
Update. Got both hatches in and took almost all the foam out. Left the foam right under the seat mount for support, just in case. If it gets waterlogged, will pull it too. Removing the foam was fun! Not! Everything did firm up once hatches were installed.
Added a lot of extra storage. Thanks again everyone for your help and advise.
Mon Sep 15, 2014 5:37 pm
That turned out really good. Enjoy the storage
Mon Sep 15, 2014 5:56 pm
Looks like they were supposed to go there!
Good job!
Sent from my beeper
Mon Sep 15, 2014 7:16 pm
Thanks, very happy with them.
Tue Sep 16, 2014 12:04 pm
Users browsing this forum: No registered users and 94 guests
cron
