It is currently Sat Jun 28, 2025 6:58 pm
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3
 Gator Glide
Post Re: Gator Glide
1754 Gator Tail Extreme
I like methanol, bring it
"I'm just a squirrel trying to get a nut..."
Tue Jul 16, 2013 3:03 pm
Were you able to put down final coat or did the rain get ya .. It just got done pouring here in kingwood
Sent from... who cares..
1744 WC Custom
25 GTR
Tue Jul 16, 2013 3:41 pm
great post, appeciate all the pictures.....I just suspended my boat today and started the sanding process. I went with the G4 in graphite and plan to do the gatorbase tomorrow.....thanks again
Tue Jul 16, 2013 9:22 pm
Well the rain finally let up so I painted the first coat of G2
Thu Jul 18, 2013 9:13 pm
U went thinner coat for sure! Looking good
Thu Jul 18, 2013 9:18 pm
Happen to apply 2nd layer this Eve ?
1744 WC Custom
25 GTR
Fri Jul 19, 2013 9:14 pm
Fri Jul 19, 2013 9:39 pm
It doesn't coat as much as they claim but with 2 coats of each it is still pretty nice if it was up to me selling it I would sell a gallon of each bc it doesn't cover very much I would rather see them cut the price some and sell it as a gallon of base and gallon of g2 or g4
Fri Jul 19, 2013 10:21 pm
You guys are just putting it on to thick, about the third coat is when you shouldn't be able to see thru it. It will still work in the thicker coat just fine but that's why your not getting as much coverage out of it. Waiting days between coats is not a good idea keep it at the 30-45 minute between coats or dry to touch and apply another coat ( Its a bonding process ) . If you wait too long you will need to re-sand surface so it will adhere properly. Looks good you will like it.
" Hardcore Waterfowler "
Wed Jul 24, 2013 6:02 am
Thu Dec 19, 2013 11:19 am
The darker the less pigment, so graphite would be black but just less pigment . That being said you will not have any adhesion issues with any of our colors because we won't put it out with to much pigment. Also GG adheres better than anything I've ever used or know of. If you prep right it isn't coming off, you have to wear it off.
http://www.gatorglide.com/
gatorheads@comcast.net
Thu Dec 19, 2013 6:38 pm
Thx, So Graphite has the least amount of added pigment?
Thu Dec 19, 2013 7:17 pm
I just did the G4 on mine. He's right if it's prep right that stuff ain't coming off. By the way I used the graphite color also.
Sent from my iPhone using 2
1854 GTB Extreme 35GTR
Fri Dec 20, 2013 5:48 am
Fri Dec 20, 2013 6:37 pm
I know this topic is a couple years old, but would you happen to remember the height of the board going across that you suspended your boat from rubberduck?
Fri Mar 06, 2015 5:54 pm
Man all the old threads are popping up. If it helps, I try to get the boat just high enough to get the trailer out and roll a 30 gal drum under it with for sanding it down. I like it a foot or two higher for painting. Makes it easy to sand with your back against the ground and easier to dip the roller with it higher.
Sat Mar 07, 2015 3:29 pm
Thanks frog, I just built the frames today and I'll be ordering some gator glide in the near future, I still have about 6 weeks or so until my new hull will be ready. Another question frog, do I still have to sand the surface on a brand new hull even though even though it's bare metal?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sat Mar 07, 2015 6:39 pm
Yes, it's not going to take you long and new stuff really need a good acetone cleaning. Wouldn't hurt to wash it with a degreaser before the acetone. Everything combined would take less than 45 min and you will eliminate any reason for failure.
Sat Mar 07, 2015 7:02 pm
I plan on using some stout degreaser and rinse well on my new hull before the acetone. The stuff we use to clean equipment is so caustic it will dissolve oil just about on contact. It's some stout stuff. That should take any oils off the aluminum since I'm having mine painted and the bottom left bare. I will have to prep and tape off a few inches up the sides. I would imagine some Simple Green, Purple Power, or plain old Dawn dish soap and a little water would do fine too.
-Custom pool noodle
-stage 4 water wings
Sat Mar 07, 2015 7:10 pm
Sat Mar 07, 2015 7:18 pm
Good info, thanks, I'll get a little degreaser from work
Sat Mar 07, 2015 7:37 pm
Users browsing this forum: Google [Bot] and 130 guests
