rubberduck
Joined: Tue May 14, 2013 5:15 pm Posts: 293 Location: Nederland, TX
 Re: Gator Glide
_________________ 1754 Gator Tail Extreme I like methanol, bring it "I'm just a squirrel trying to get a nut..."
Tue Jul 16, 2013 3:03 pm |
calphil
Joined: Sun Feb 26, 2012 10:49 pm Posts: 1715 Location: Kingwood,TX
 Re: Gator Glide
Were you able to put down final coat or did the rain get ya .. It just got done pouring here in kingwood
Sent from... who cares..
_________________ 1744 WC Custom 25 GTR
Tue Jul 16, 2013 3:41 pm |
woodsman1977
 Re: Gator Glide
great post, appeciate all the pictures.....I just suspended my boat today and started the sanding process. I went with the G4 in graphite and plan to do the gatorbase tomorrow.....thanks again
Tue Jul 16, 2013 9:22 pm |
rubberduck
 Re: Gator Glide
Well the rain finally let up so I painted the first coat of G2
Thu Jul 18, 2013 9:13 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
 Re: Gator Glide
U went thinner coat for sure! Looking good
Thu Jul 18, 2013 9:18 pm |
calphil
 Re: Gator Glide
Happen to apply 2nd layer this Eve ?
Fri Jul 19, 2013 9:14 pm |
rubberduck
 Re: Gator Glide
Fri Jul 19, 2013 9:39 pm |
AKA Freshwaterkilla
 Re: Gator Glide
It doesn't coat as much as they claim but with 2 coats of each it is still pretty nice if it was up to me selling it I would sell a gallon of each bc it doesn't cover very much I would rather see them cut the price some and sell it as a gallon of base and gallon of g2 or g4
Fri Jul 19, 2013 10:21 pm |
lurejerk
Joined: Sun Jun 02, 2013 7:06 am Posts: 78 Location: Cowtown- Tx
 Re: Gator Glide
You guys are just putting it on to thick, about the third coat is when you shouldn't be able to see thru it. It will still work in the thicker coat just fine but that's why your not getting as much coverage out of it. Waiting days between coats is not a good idea keep it at the 30-45 minute between coats or dry to touch and apply another coat ( Its a bonding process ) . If you wait too long you will need to re-sand surface so it will adhere properly. Looks good you will like it.
_________________ " Hardcore Waterfowler "
Wed Jul 24, 2013 6:02 am |
schauv01
Joined: Wed Oct 03, 2012 6:50 am Posts: 565 Location: Union, LA
 Re: Gator Glide
Thu Dec 19, 2013 11:19 am |
Frog
 Re: Gator Glide
The darker the less pigment, so graphite would be black but just less pigment . That being said you will not have any adhesion issues with any of our colors because we won't put it out with to much pigment. Also GG adheres better than anything I've ever used or know of. If you prep right it isn't coming off, you have to wear it off.
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Thu Dec 19, 2013 6:38 pm |
schauv01
 Re: Gator Glide
Thx, So Graphite has the least amount of added pigment?
Thu Dec 19, 2013 7:17 pm |
dirtybird29+
Joined: Mon Feb 15, 2010 8:03 pm Posts: 393 Location: South Carolina
 Re: Gator Glide
I just did the G4 on mine. He's right if it's prep right that stuff ain't coming off. By the way I used the graphite color also.
Sent from my iPhone using 2
_________________ 1854 GTB Extreme 35GTR
Fri Dec 20, 2013 5:48 am |
Frog
 Re: Gator Glide
Fri Dec 20, 2013 6:37 pm |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
 Re: Gator Glide
I know this topic is a couple years old, but would you happen to remember the height of the board going across that you suspended your boat from rubberduck?
_________________ 1648 weld bilt being followed by a 35 gtr
Fri Mar 06, 2015 5:54 pm |
Frog
 Re: Gator Glide
Man all the old threads are popping up. If it helps, I try to get the boat just high enough to get the trailer out and roll a 30 gal drum under it with for sanding it down. I like it a foot or two higher for painting. Makes it easy to sand with your back against the ground and easier to dip the roller with it higher.
Sat Mar 07, 2015 3:29 pm |
Quackkillz
 Re: Gator Glide
Thanks frog, I just built the frames today and I'll be ordering some gator glide in the near future, I still have about 6 weeks or so until my new hull will be ready. Another question frog, do I still have to sand the surface on a brand new hull even though even though it's bare metal?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sat Mar 07, 2015 6:39 pm |
Frog
 Re: Gator Glide
Yes, it's not going to take you long and new stuff really need a good acetone cleaning. Wouldn't hurt to wash it with a degreaser before the acetone. Everything combined would take less than 45 min and you will eliminate any reason for failure.
Sat Mar 07, 2015 7:02 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Gator Glide
I plan on using some stout degreaser and rinse well on my new hull before the acetone. The stuff we use to clean equipment is so caustic it will dissolve oil just about on contact. It's some stout stuff. That should take any oils off the aluminum since I'm having mine painted and the bottom left bare. I will have to prep and tape off a few inches up the sides. I would imagine some Simple Green, Purple Power, or plain old Dawn dish soap and a little water would do fine too.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sat Mar 07, 2015 7:10 pm |
Frog
 Re: Gator Glide
Sat Mar 07, 2015 7:18 pm |
Quackkillz
 Re: Gator Glide
Good info, thanks, I'll get a little degreaser from work
Sat Mar 07, 2015 7:37 pm |
