It is currently Sat Jun 28, 2025 8:03 am
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 Gator glide chipping
Post Gator glide chipping
From my understanding, gator glide is supposed to wear like paint right? At the very front of my gator glide just under the bow of the boat, i have huge chunks of GG missing. And it just peels righf off. But the front never gets hit by anything. At the back of the boat though where it takes all the hits from stumps and what not its just got a few scratches but no chunks missing. Anyone know what could be causing this? ImageUploadedByTapatalk1427332300.779715.jpg
Wed Mar 25, 2015 7:12 pm
Post Re: Gator glide chipping
You sure that's not steel flex ? It will chip. Did you apply the GG your self or bought the boat with it on it ? Mine never chipped .
Wed Mar 25, 2015 7:35 pm
That looks like sub-par prep work.
Wed Mar 25, 2015 7:56 pm
Was it a brand new boat? If so, the alum will have a machine oil as part of the sheet fabrication process. A simple solvent will remove it. If left on, most paint will not bond. If the paint came off in sheets, then it is plenty strong and a good molecular bond to other paint.
If flex is the cause, it will show cracks first or in adjacent areas.
2014 PD 18x54 SBX w/ 36 EFI PD E5
Wed Mar 25, 2015 8:06 pm
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Wed Mar 25, 2015 8:20 pm
The boat was about a year an half old when i put on the gator glide myself. At the back of the boat nearly all the paint was gone and the front where it is chipping was still looking brand new, almost all the paint was still there (Was told not necessary to remove it). Took some sand paper to the whole boat, pressure washed it, then after it dried i wiped the whole thing down and used every drop of a 1gallon can of acitone. Did a quick wipe down between every coat as well
Wed Mar 25, 2015 8:24 pm
I have the same problem, used about a gallon of acetone on the repair and happening again. Sorry but prep isn't an issue on mine, I know prep work.
Wed Mar 25, 2015 8:25 pm
Frog??? Need your input . Is this a hull flexing issue?? . I'm stumped .
H Finn
BACKWATER PROSTAFF
Wed Mar 25, 2015 8:29 pm
viewtopic.php?f=2&t=54420
Yeah i did everything i could. The bottom was damn near bare aluminum. Heres the pic and a link to when i did it
Wed Mar 25, 2015 8:30 pm
Can outside temp , humidity, or weather conditions affect the bond between the GG and the hull the same as painting a boat ?
Wed Mar 25, 2015 8:38 pm
I cannot chip, scrape or scratch that stuff on my rig even if I wanted to - crazy
Wed Mar 25, 2015 8:40 pm
Another option- paint mixing? Or primer.
Wed Mar 25, 2015 8:57 pm
If not prep then I'd have to guess it would be due to high humidity when applying not allowing it to adhere like it should.
Wed Mar 25, 2015 8:58 pm
Wed Mar 25, 2015 9:00 pm
Hell idk. It sat upside down like that inside an insulated garage for like 2 weeks surely that was enough time. May have been humidity though idk it's always humid here it's horrible..
Wed Mar 25, 2015 9:03 pm
I've never installed GG (yet)... However being told it's basically just like applying any other paint, you'd be better of apying it on a bright sunny day outside. The air needs to be as dry as possible. I know that's not realistic in this part of the world every day but you just have to pick and choose when you apply it wisely. I'd let it cure outside as well. Being inside that shop insulated or not could have held some moisture. Plus, you know how things like to sweat and condense water on the surface when inside a shop... I know stuff in my shop does if the conditions are right
Wed Mar 25, 2015 9:06 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Wed Mar 25, 2015 9:12 pm
May have been leaving it inside idk we'll see what frog says.
I did it right in the middle od summer so it was plenty hot and sunny..Did it out in the driveway too, only rolled it inside after i was done and then stayed there for 2 weeks. Who knows. Can that be fixed easy as painting a gew new coats over the holes?
Wed Mar 25, 2015 9:14 pm
There he is lol. I'll try to get a better pic but it was kinda hard with the location. Its right where the bottom begins to rise into the rake.
Wed Mar 25, 2015 9:18 pm
Wed Mar 25, 2015 9:20 pm
Majority of the chipping is the general area of the right half of this pic. This was taken when i installed it.
Wed Mar 25, 2015 9:21 pm
Wed Mar 25, 2015 9:23 pm
:lol: there was very little if any paint left on the bottom as seen in the other pic i posted a few posts back.
The boat sits on the bank for a day or two at a time when i go to the camp house but its just grass so I wouldn't think that could do it...?
Wed Mar 25, 2015 9:26 pm
It did in the past, but after i put the GG on im alot more cautious with it. Dont cross logs unless i have to bit even then i go slow and power over em.
Wed Mar 25, 2015 9:30 pm
Wed Mar 25, 2015 9:34 pm
Guess we'll never know! Lol
Can i i just paint a few layers back over the holes to patch it up? Or is it so slick that not even gator glide will stick to gator glide? :lol:
Wed Mar 25, 2015 9:39 pm
Wed Mar 25, 2015 9:59 pm
Thanks for the help, i'll try and get that done and patched up
Thu Mar 26, 2015 6:13 am
I would blame the paint, seeing as how Go-Devil paints their hulls with water colors it seems like :lol:
Thu Mar 26, 2015 7:32 am
:lol:
Thu Mar 26, 2015 7:41 am
Thu Mar 26, 2015 8:17 am
Thu Mar 26, 2015 8:19 am
Go-devil's paint has always been pretty solid! I have a few friends with older GD and the paint is holding up well. Another guy I know got one about a year ago and the paint came apart, they said they had tried something new on a couple boats and it wasn't working out. Told him to go get the boat repainted and send them the bill. He said he did and they did. Pretty stand up!
Thu Mar 26, 2015 12:21 pm
Planning on repainting mine this summer. It's getting bad, bare aluminum in alot of places. I hunt a cypress swamp pretty often so it takes a beating. Gonna try and paint bedliner along the gunnels all the way around and see how that does. Does the spray paint bedliner weigh a whole lot? Thinking about doing that as a base coat for the whole boat the going over it with green if it holds up well
Thu Mar 26, 2015 12:28 pm
The paint is the only major disappointment on my go-devil. I've got a perfect outline of the bottom of a jerry-can from hauling the boat home with the can on the floor once. It's a problem I can live with, because I bought the thing knowing most of the boat was going to get covered with either hydroturf or GG. It's just disappointing that the handful of times I've run it have left it looking like I drove it through buckbrush for an entire season.
Thu Mar 26, 2015 1:55 pm
are both these boat newer?
Thu Mar 26, 2015 2:03 pm
Mines either 2015 or very late 2014.
Thu Mar 26, 2015 2:06 pm
Thu Mar 26, 2015 2:10 pm
Thu Mar 26, 2015 2:28 pm
