It is currently Sun Jun 29, 2025 7:33 am
Reply to topic  [ 121 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Go-Devil Boat with GTR
Post Go-Devil Boat with GTR
Tue Jan 06, 2015 2:59 pm
Post Re: Go-Devil Boat with GTR
Boxing in the transom or trim tabs will likely fix it.
Tue Jan 06, 2015 9:14 pm
I don't know why your so adiment about flotation. I gained 2 mph by removing the floatations out of my boat. You do know if you take in water , the boat will float but it will float vertically in the water. Once the flotation gets wet it becomes water logged. The foam in my deck and transom were wet at the bottom 6 inches . Was a lot of mush and a bitch to remove ( turbo nozzle does the job but it's messy ) . I probably removed 150lbs of foam out of my boat and much of it was wet. I was able to gain storage by removing the foam as well as better performance.
Wed Jan 07, 2015 1:33 am
Wed Jan 07, 2015 7:19 am
Ok you will regret it, good luck finding what you want though
Wed Jan 07, 2015 2:17 pm
Nope, don't think I will. Thanks though.
Wed Jan 07, 2015 5:37 pm
Put insurance on it if it sink get ur money and go buy another my 1644 had it under floor and frint deck and was bad water logged just the foam under the floor was probably close to 300 i couldnt even pick up just from the bench to back i actually like the cut back transom i pull up on sandbars alot and helps pushing back a square transom digs real bad in the sand try to push off
1440 xpress 23 gdsd... Sold
1644 gd 35 gtr
Thu Jan 08, 2015 11:05 am
^ yep mine has insurance
Fri Jan 09, 2015 12:45 am
Fri Jan 09, 2015 2:25 am
Fri Jan 09, 2015 2:26 am
I had an 1844 GD hull with a modded PD on it and it flat out ran. The little bit of performance lost because of the cutback transom is so minor it would take an engineering degree to calculate.
With my previous powerhead that had, cam, carb, headwork and exhaust it ran 34 with me at 240, 12gal gas and safety equipment.
Fri Jan 09, 2015 10:40 am
Fri Jan 09, 2015 1:57 pm
Fri Jan 09, 2015 2:17 pm
Fri Jan 09, 2015 3:26 pm
Fri Jan 09, 2015 3:30 pm
If you boat takes on water it will float but will float vertical in the water . I removed mine because my boat only runs mainly in 3 to 4 foot of water so flotation Is pointless. My boat only has 18" sides , so I wouldn't take it in deep water anyway.
Fri Jan 09, 2015 7:20 pm
Fri Jan 09, 2015 8:39 pm
I removed the floatation box in the back of my boat but kept the side floatation and front floatation in. I actually like the side floatation boxes because I use it to stand on all the time. I does not bother me if any boat I own has or does not have floatation. I keep mine covered and it does not get water logged.
40HP Gatortail
Fri Jan 09, 2015 8:55 pm
So your saying The weight of the mud motor ( 250lb's give or take ) will not make it float vertical in the water if the boat gets submerged ? If you want keep the flotation it better safe then sorry. I just prefer it with out it ( less weight ) . You can cover your boat if you want but soon as it rain when your pulling the boat or any water that comes into the boat fishing or hunting will absorb into the foam. USCG approved only means the boat will float in the water does not have to be level. Besides if your boat is submerged in water and your in it. what you going to do try to paddle that sucker to shore ? You will have to remove the foam anyway even after you do retrieve the boat it's water logged and the foam will need to be removed. That's why mines insured. If mine sinks then I get more money the boats worth lol. BTW guess yall don't buy john boats or any other boats without flotation ?
Sat Jan 10, 2015 5:03 am
Sat Jan 10, 2015 12:45 pm
You wouldn't of ever been able to replace my foam with out taking off the front of my front deck , then welding it back on. My boat does not have a lil small deck like the newer boats
Sat Jan 10, 2015 2:58 pm
Sat Jan 10, 2015 6:39 pm
Whatever floats your boat lol. Is the floor in your boat foam filled as well ? Mine is. I didn't remove it since it helps dampen the noise.
Wed Jan 14, 2015 9:12 pm
Btw I left the wet foam removed from my throat in an open trash can for a week . Didn't rain the whole week. Was still as wet as when I put the foam in the trash can
Wed Jan 14, 2015 9:14 pm
we got way off topic here
40HP Gatortail
Wed Jan 14, 2015 10:10 pm
Thu Jan 15, 2015 12:48 am
Thu Jan 15, 2015 6:51 am
Thu Jan 15, 2015 10:33 am
Burlap Brothers
Thu Jan 15, 2015 10:55 am
Your argument was the foam will not hold water. My point was that it obviously did. The foam that was not wet before but was after I cut out the foam using the power washer and turbo nozzle held water as well . Any water that touched the foam was trapped in the foam itself.
Thu Jan 15, 2015 11:29 am
I am in the same position as you (designing and getting ready to buy a boat) and these guys can give you a lot more personal experience based advice on your other questions but I just wanted to throw out there that you should take a look at Prodigy. I have looked and looked and called all the major manufacturers and most of the custom ones and chose Prodigy. The quality and fit and finish are awesome (have seen several in person and rode in them), and their prices are competitive with "off the shelf" models. I havent owned a mud boat yet so take my advice for what it is, but that's who is getting my hard earned money and why.
2015 Prodigy 1954 V-Rake w/GTR35 (heads, cam, exhaust, EFI)
Full Review of My Rig Here:
Thu Jan 15, 2015 11:44 am
Thu Jan 15, 2015 1:58 pm
I really like the prodigy's . I own a Go-Devil boat but myself. I'm currently deciding if I want a prodigy or wccustom . Custom is the way to go. GD boats are nice but a custom you get get the exact layout or hull design you want. Far as flotation is concerned why don't you just ask if you can get the flotation sealed off air tight , that way you won't have issues down the road.
Thu Jan 15, 2015 7:46 pm
Thu Jan 15, 2015 10:06 pm
40HP Gatortail
Thu Jan 15, 2015 10:21 pm
Thu Jan 15, 2015 11:45 pm
40HP Gatortail
Fri Jan 16, 2015 2:04 am
Fri Jan 16, 2015 7:04 am
40HP Gatortail
Fri Jan 16, 2015 7:35 am
Users browsing this forum: Google [Bot] and 152 guests
