It is currently Tue Jul 22, 2025 12:02 pm
Reply to topic  [ 28 posts ]
 Round chime custom boat
Post Round chime custom boat
Can they build a round chime using 3/16 or do they simply bend it 3 times. What works better.
Thinking of upgrading my boat for 2014
Mon Oct 28, 2013 4:28 pm
Post Re: Round chime custom boat
Camo had unc j build him a round chine boat a while back. I want to say they bent in like 10x per side to create the round chine. Try to google team camo edition uncle J. It was years ago he did this. Not sure if it was 3/16 or not.
1754 GTB / 35 GTR
Mon Oct 28, 2013 5:33 pm
my 1850 round chine has 9 brakes per side 3/4'' apart it turned out nice. its 1 piece 1/8'' hull. the next 1 i do will be 3/16'' bottom with round chine then 1/8'' sides
Mon Oct 28, 2013 6:24 pm
HOTSAUCE170 wrote:
Mon Oct 28, 2013 6:33 pm
havent been able to work on it much im putting on catwalks now got to brake lids for front deck and boxes. im still trying to decide on latches for boxes. im using rotary latches so everything is inside like a car hood latch. i also made my own seat bases flush with deck so turf will lay flat and no base showing
Mon Oct 28, 2013 6:50 pm
Mon Oct 28, 2013 8:25 pm
Thinking of designing a new boat for running timber. Pointed bow, round chime.
Will use my 1854 for duck hunting on the lake. This boat will be smaller and more maneuverable. Pointed bow is the way to go in timber. Hit a couple of trees( Mostly due to current) and momentum. A pointed bow will remedy that.
Going with a 25 gtr on this one.
Tue Oct 29, 2013 5:52 pm
Tue Oct 29, 2013 6:20 pm
Tue Oct 29, 2013 6:49 pm
My godevil sucked to turn at low speeds, I assumed it was because I had to lift the motor out the water and then it'd spin all over hell. Does a round chine still steer well when using a surface drive at low speeds?
Tue Oct 29, 2013 6:56 pm
Tue Oct 29, 2013 7:12 pm
You will hate a round chine idling through the woods.
Tue Oct 29, 2013 8:33 pm
What would be the best in the woods then? All I've ever been in is a square chine and I can run it very well idling and about half throttle in tight areas.
Round is better at higher speeds right?
Is a triple taper any better? Seems like the same idea to me but less breaks than a round.
Sent from my beeper.
Tue Oct 29, 2013 8:40 pm
Mine is triple tapered and tracks pretty well. Much better than a straight round. It's almost round in the back so it still digs in the turns pretty well, but it's got a pretty hard edge the further forward you go. At idle, there is quite a bit of square in the water. I don't know all the math that goes into it, but I've ridden in squares, rounds, single tapered's, double, and triples, and rounds don't track for shit at low speed. They are built to turn at high speeds and they do that well as long as you have more than a couple inches of water. The tapered chine boats still track pretty well, IMO. Maybe not quite as well as a square, but pretty damn close.
Tue Oct 29, 2013 8:44 pm
Places like this is where you want a round chine. It'll help you slide off stumps more. Yes they are a pain to turn but it has become second nature driving it that I don't notice it any longer. It's not bad when going against a current but when the current is pushing you and you are idling you better keep your hands in the boat cause your gonna be bouncing off shit like a tennis ball. You learn to use the trees to help you steer.
[/quote]
17*38 Klibert 23GDLT
Wed Oct 30, 2013 1:39 am
[/quote]
Wed Oct 30, 2013 1:40 am
Rudy, it's chiNe, not chiMe....and Don't pronounce the "whale" in Gunwale, it's pronounced 'gun*nel'.
Wed Oct 30, 2013 1:47 am
Wed Oct 30, 2013 4:38 am
Wed Oct 30, 2013 5:37 am
Cool Vid
Wed Oct 30, 2013 6:15 am
Wed Oct 30, 2013 6:22 am
Wed Oct 30, 2013 6:25 am
its ok if youre scared to bust some runs!
Wed Oct 30, 2013 6:40 am
I've had absolutely 0 problems using a square chine in thick woods and stumps.
You get a narrow boat with a lil weight to it and a square chine won't slide
Wed Oct 30, 2013 7:00 am
Skiff
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Oct 30, 2013 7:03 am
Wed Oct 30, 2013 7:13 am
Wed Oct 30, 2013 7:18 am
Wed Oct 30, 2013 7:21 am
Users browsing this forum: No registered users and 113 guests
