It is currently Mon Jul 14, 2025 8:14 am
Reply to topic  [ 33 posts ]
 Chines
Post Chines
I've only built square chine boats and never played with double or triple tapers before. What is a double taper? A bottom that has 2 brakes in it? What is a triple? A bottom that has 3 brakes?
What is this one?
Sent from my beeper
Fri Mar 14, 2014 10:16 am
Post Re: Chines
That was someone attempting to build a round chine, but who said to hell with it.
Fri Mar 14, 2014 10:24 am
Post Re: Chines
Looks like my double taper .. Drafts a little deeper and doesn't slide in turns as bad ... Kinda similar to driving an extreme hull
1744 WC Custom
25 GTR
Fri Mar 14, 2014 10:25 am
Post Re: Chines
Fri Mar 14, 2014 10:34 am
Post Re: Chines
PD just calls it a tapered chine. IDK if that would be considered a double, or a triple.
Fri Mar 14, 2014 10:46 am
Post Re: Chines
Fri Mar 14, 2014 10:48 am
Post Re: Chines
Fri Mar 14, 2014 11:34 am
Post Re: Chines
That's a double taper. Triple taper will have one more break and be closer to "round". Here's a single taper
Fri Mar 14, 2014 12:20 pm
Post Re: Chines
Technically a square chine is a single taper... but most dont refer to it as such. The one you have pictured is a trippple... count the changes in angle not including performance crimps...
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Fri Mar 14, 2014 7:44 pm
Post Chines
Fri Mar 14, 2014 7:45 pm
Post Re: Chines
Fri Mar 14, 2014 7:52 pm
Post Re: Chines
Fri Mar 14, 2014 8:51 pm
Post Re: Chines
Which ones you prefer?
40HP Gatortail
Fri Mar 14, 2014 9:35 pm
Post Re: Chines
Who
Fri Mar 14, 2014 9:53 pm
Post Re: Chines
Double taper, I know turns good
Fri Mar 14, 2014 10:58 pm
Post Re: Chines
Sat Mar 15, 2014 12:47 am
Post Re: Chines
If you are running a narrow boat, you can get away with square chines. My 42" bottom doesn't slide.
A wide boat will turn a lot harder than a narrow one. If I went anything over 48" I'd have a taper chine.
Sun Mar 16, 2014 9:00 pm
Post Re: Chines
The boat in pic and PD have always used a Double Taper or Square
Square is not a single taper whoever said that, Square is straight side to bottom
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Wed Mar 19, 2014 4:37 pm
Post Re: Chines
I like tapered chines the best. However, square chines draft better for shallow water than any of them. I like tapered because they turn a little better.
40HP Gatortail
Wed Mar 19, 2014 4:48 pm
Post Re: Chines
Wed Mar 19, 2014 5:38 pm
Post Re: Chines
40HP Gatortail
Wed Mar 19, 2014 5:42 pm
Post Re: Chines
Pete Willett
Wed Mar 19, 2014 5:52 pm
Post Re: Chines
All chines slide in the skinny stuff.... for deeper water that is true but the narrower you go with a square chine the less it slides.... my 1840 will turn on a dime in the deeper water.....unless all your weight is on the high side in a turn, you will take the boat off edge and slide.
you drink the kool aid, id rather drink the whiskey and raise hell!!!!
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Wed Mar 19, 2014 5:53 pm
Post Re: Chines
Wed Mar 19, 2014 5:54 pm
Post Re: Chines
40HP Gatortail
Wed Mar 19, 2014 6:03 pm
Post Re: Chines
I've never had a problem out of a square chine but I just felt like experimenting and trying it out. Might go with a double then go from there.
Sent from my beeper
Wed Mar 19, 2014 6:07 pm
Post Re: Chines
[quote="North LA Hunter"]I've never had a problem out of a square chine but I just felt like experimenting and trying it out. Might go with a double then go from there.
Sent from my beeper[/
I am interested to know how the double performs
40HP Gatortail
Wed Mar 19, 2014 6:11 pm
Post Re: Chines
Pete Willett
Wed Mar 19, 2014 7:52 pm
Post Re: Chines
That very well may be the case.
40HP Gatortail
Wed Mar 19, 2014 8:48 pm
Post Re: Chines
Excel and Prodigy Boats are triple chine.
Thu Mar 20, 2014 8:15 am
Post Re: Chines
40HP Gatortail
Thu Mar 20, 2014 8:33 am
Post Re: Chines
Thu Mar 20, 2014 11:08 am
Post Re: Chines
Triple handles well, but they aren't usually broke as far forward and the break isn't usually as severe a true round so they don't draft as much water, imo. I like the compromise.
Thu Mar 20, 2014 11:11 am
Users browsing this forum: No registered users and 75 guests
