It is currently Tue Jul 15, 2025 4:06 am
Reply to topic  [ 32 posts ]
 Trim tab
Post Trim tab
I have a 18x46 homemade 3/16 bottom 6 ft deck with aluminum gas tank in front it always tended to ride low in the front and the guy that built my boat left a 1.5" strip across the back of the boat kinda like a trim tab so tried to bend it up to get the front of the boat more out the water we'll it did but now it's letting to much water hit the bottom of the belt housing. And it's kicking the motor up and that on the biggest pin setting I was wondering why it did that I tried to bend it back down in the center but I haven't ran it yet. Any idea why it did that I dint bent it up
Much at all
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Mon Apr 14, 2014 6:12 am
Post Re: Trim tab
How tall is your transom?
Mon Apr 14, 2014 6:14 am
Post Re: Trim tab
A buddy of mines rig was just like that except the trim tab thing. He had to get bigger tabs from Coco and put on it.
Sent from my beeper
Mon Apr 14, 2014 6:17 am
Post Re: Trim tab
Try trimming 1" off that strip. 1.5" is quite long.
Mon Apr 14, 2014 6:18 am
Post Re: Trim tab
You can bend the middle back down at the motor and leave the sides bent up. Or completely remove a section in the middle but I wouldn't do that unless it was a last resort.
Mon Apr 14, 2014 6:24 am
Post Re: Trim tab
I'm not sure the guy who built it builds gator tails boats for gator tail ima measure it when I get home I told him 21 transom but I think he might have messed up because I have 18 sides and it don't seem like like the transom is 3 inches higher than the sides
Mon Apr 14, 2014 6:29 am
Post Re: Trim tab
Mon Apr 14, 2014 6:42 am
Post Re: Trim tab
I worded it like that because when I was lookig to get one built everybody I called said they build boats just like gator tail boats I should have just said he builds boats for gator tail man y'all don't let anything slide on here
Mon Apr 14, 2014 6:52 am
Post Re: Trim tab
I think my transom might be short measured it two ways from the cement to bottom of my boat is
23.750 - 43.250 to top of transom = 19.5 and from bottom of boat to top of transom measured on the angle is 20.750
Mon Apr 14, 2014 2:37 pm
Post Re: Trim tab
Top of transom, measured straight down, not against the transom, should be 21" for a tall transom Gator-Tail.
Mon Apr 14, 2014 2:47 pm
Post Re: Trim tab
I couldn't get a good measurement like that because I bent that tap up so I just did the math
Mon Apr 14, 2014 3:34 pm
Post Re: Trim tab
I just went eyeball I hooked the tapemeasure to top of transom and let it hand it's it's perty close to 19.5 it's Deff not no 21 inches
Mon Apr 14, 2014 3:45 pm
Post Re: Trim tab
Could I put a spacer and run it with out welding it on to make sure it runs how it suposed to before I have it welded up
Mon Apr 14, 2014 4:40 pm
Post Re: Trim tab
Mon Apr 14, 2014 4:57 pm
Post Re: Trim tab
Do they make a 1 1/2 square tubing or gonna have to go 2x2 and cut it
Mon Apr 14, 2014 5:04 pm
Post Re: Trim tab
They make 1.5" square
Mon Apr 14, 2014 5:06 pm
Post Re: Trim tab
Where you located I probably have some scrap
Post Re: Trim tab
St.martinville
Mon Apr 14, 2014 5:11 pm
Post Re: Trim tab
18x60 WC CUSTOM propelled by a 35GTR (25mph with a slight chop and a 6mph tailwind................:)
Mon Apr 14, 2014 5:17 pm
Post Trim tab
Mon Apr 14, 2014 10:05 pm
Post Re: Trim tab
Tue Apr 15, 2014 8:18 am
Post Re: Trim tab
This is the measurement to get right 2 ppl told me two diffrent ways to measure
Tue Apr 15, 2014 11:31 am
Post Re: Trim tab
21" measured on a vertical line from the top of the transom down to a straight edge off the bottom of the boat
Tue Apr 15, 2014 11:34 am
Post Re: Trim tab
Tue Apr 15, 2014 11:35 am
Post Re: Trim tab
Once I get the spacer on there can I just leave it siting on there and drill new holes for the bolts and bolt it down because gonna make me nervous welding around all them fuel lines
Wed Apr 16, 2014 3:20 am
Post Re: Trim tab
Soooo move the fuel line before you weld... :?
Wed Apr 16, 2014 7:13 am
Post Re: Trim tab
I got a water separator fuel pump all on the transom and it's all self tapping screws so once I take them off they not gonna hold
Wed Apr 16, 2014 7:32 am
Post Re: Trim tab
Just lay a wet towel over it, you'll be fine.
Wed Apr 16, 2014 7:34 am
Post Re: Trim tab
I bent it down a tad went run it by ma self it wasant hitting the belt housing any more but it's damn close and it starts to tap when I trim all the way up and stand at back of the boat up against the motor I think with a load it will start to hit again will picking up the motor make it tap more or it shouldn't mess with that
Wed Apr 16, 2014 5:22 pm
Post Re: Trim tab
Use jb weld and sand it smooth. No need to weld and grind.
Wed Apr 16, 2014 5:52 pm
Post Re: Trim tab
Sell that boat man! O never mind that's the one that came off the trailer and landed on the black top upside down! Lmao
Sent from da woods!
Sat Apr 19, 2014 8:25 pm
Post Re: Trim tab
20' homemade skiff with a stage 2 gtr
Sat Apr 19, 2014 10:59 pm
Users browsing this forum: No registered users and 81 guests
