It is currently Wed Jul 16, 2025 7:57 am
Reply to topic  [ 22 posts ]
 Patching interior Holes in aluminum
Post Patching interior Holes in aluminum
Anyone know how to patch a small screw hole on the inside a boat? Previous owner decided to attach all kinds of shit on the inside and I can't stand looking at all of them.
I was thinking I would use some sort of epoxy to fill the holes and then sand it flat and repaint. Any thoughts?
Mon May 19, 2014 6:59 pm
Post Re: Patching interior Holes in aluminum
Patch aluminum with aluminum.
18'x54"CC Hanko/ 36PD
Mon May 19, 2014 7:29 pm
Or 3M Scotchkote 226 sticks if you don't have access to a welder.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon May 19, 2014 7:32 pm
Jb weld spread thin over the hole then sanded and painted should work.
Tue May 20, 2014 6:32 am
^ this is what I did on my old boat before I sold it worked good.
Tue May 20, 2014 7:14 am
Thanks guys, jb weld it is
Tue May 20, 2014 8:32 am
Put a rivet in it.
Tue May 20, 2014 8:47 am
take a grinder and grind it down to bare metal inside and out on all the holes and take it to a local welder and have em welded. you take all the prep work out by having it to bare metal and shouldn't cost you much
Tue May 20, 2014 8:54 am
Where u located?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Tue May 20, 2014 10:27 am
Kansas. A weld would be nice but the epoxy would get the job done and probably be easier. There's no structure concern so if I can plug it with glue I'll just do that
Tue May 20, 2014 2:24 pm
They do make some filler rods for aluminum if u have a torch... could solder them in with it and sand them down. Just dont let it get toooo hot.
Wed May 21, 2014 8:02 am
Wed May 21, 2014 12:09 pm
DON'T put JB weld on it or you costing yourself way more money when it starts leaking again and the welder has to spend forever getting that bull shit JB weld off
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Wed May 21, 2014 6:59 pm
The holes are purely cosmetic annoyances. I'll take pics and post them - they're from where the previous owner tried attaching stuff
Wed May 21, 2014 8:51 pm
Ideally welding would be the best option but if its just a cosmetic fix to plug a small hole where u dont have to worry bout leaks and don't have access to a welder. I had a few drill bit holes on the bow and bench seat. Rivets or welding is a much better option for structural repairs on a tin can boat you might get a bit of burn through if your not proficient at welding aluminum
Wed May 21, 2014 8:57 pm
Wed May 21, 2014 9:41 pm
Stupid holes like the ones you see. There's more, I just don't have pics on my phone right now. I'm cleaning this boat up to "like new" again status
Wed May 21, 2014 9:42 pm
Go get ya a cheap torch from lowes and some low heat rods from harbot freight. Or both from hf and clean the area and braze them in. Get on youtube and look tor directions. Or bring it to a welder.
Wed May 21, 2014 11:16 pm
If you are going thru the trouble of making the boat "like new" find a welder and do it right. If not, I have filled a lot of holes in aluminum rigging with an aluminum rivet the paint. Can't fill those rivnut holes that way.
17' CAT 5 with 37 GTR
Thu May 22, 2014 9:31 am
If that is as small as the holes are, the welder will have it done in no time. I'm with everyone else on this. If you have a grinder, get a tiger disc, bout 60 grit. Sand a small area around each hole to be "tacked". That way the welder just has to pull the trigger on each hole and be done with it. You will be suprised how fast a screw hole fills up. Then to cut some time down, just have the welder tack the holes. You take the tiger disc and sand down the welds to a flush smooth finish. Done. I'm wiling to bet that it would take him longer to set his machine up, gather his helmet and gloves, then to weld up screw holes.
Wed May 28, 2014 4:50 am
Just for the record, jb waterweld worked great. Biggest hole was about the size of a nickel. Patched and sanded, can't tell the hole was ever there
Mon Jun 09, 2014 7:01 pm
Users browsing this forum: Google [Bot] and 75 guests
