Frog
 spider cracks in hull
Got a guy who wrote to me about spider cracks in his hull. Wanted to know if gg would help. I told him no. He sent me pic and the hull doesn't look like it got a dent in it. He says he does not run it hard and its obvious. the bottom is 1/8 5086. Any of you see or dealt with this?
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Thu Jul 31, 2014 9:07 am |
Will
 Re: spider cracks in hull
Electrolysis can causing pitting leading to cracks, can't tell by the picture but that would be my first guess.
Thu Jul 31, 2014 9:23 am |
krogers
Joined: Fri Oct 29, 2010 8:24 am Posts: 1958 Location: Bristol, FL
Tell him to quit shocking fish. I was told this can happen. Lol
_________________ 1754 GTB / 35 GTR
Thu Jul 31, 2014 9:32 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
Electrolysis?
_________________ that's going itch when it dries
Thu Jul 31, 2014 9:33 am |
Frog
That was My first thoughts but says he's got a battery switch and you can see the boat doesn't set in the water much. How would you fix it?
Thu Jul 31, 2014 9:41 am |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
My boat was 1yr old when i did my Gator glide....
When i lifted it off the trailer everywhere it sat on a bunk board it was ate up and worm holed from electrolosis.
I was explained that this is caused by the copper content in the treated bunk boards reacting with the aluminum....Even where my boards are bolted to the trailer its corroded pretty bad!!!
Thu Jul 31, 2014 9:43 am |
msm8281
Use cypress boards. So they don't rot and u won't have to worry about the chemicals.
Thu Jul 31, 2014 9:52 am |
silers27
Thu Jul 31, 2014 9:54 am |
Frog
Thu Jul 31, 2014 9:56 am |
tchauvin
Yep,,,im fixing to go get some here soon. I was given an old Hay Barn built from 1x12'' cypress planks and 2x4 studs...I will be using it in my house. So will defenatly use that on the boat trailer.
I wasnt a happy camper to see that fairly new hull looking that way. Luckily it wasnt all the way though....The gator glide filled it in nicely.
tchauvin
Thu Jul 31, 2014 10:00 am |
msm8281
Mostly salt water?
Thu Jul 31, 2014 10:01 am |
Frog
I have to jack my own thread and say "another reason to have GatorGlide on the bottom  "
Thu Jul 31, 2014 10:05 am |
BoatDR
Any chance he has an onboard charger?
Thu Jul 31, 2014 10:07 am |
Frog
Cant see under his bunks, but the bottom where the cracks are it don't look that pitted. Did the PT buck thing cause electrolysis or was it acidic? Don't know about an on board charger yet but he did run a Honda generator with rubber mount but it would have powered lights. I would think it would take a lot of bow fishing to do that and the bottom wear doen't show that. Once he resolves the why, How would you repair this? Just drill and weld I would guess. I'm not a welder but would guess if the metal was that punky from electrolysis the welder would know right away!
Thu Jul 31, 2014 10:35 am |
Will
Thu Jul 31, 2014 10:56 am |
Will
Also, when he was running the genny and lights, everything needs to go back to the genny and be isolated, dont use the hull as a ground/neutral...
Thu Jul 31, 2014 10:58 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
Thu Jul 31, 2014 11:01 am |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Thu Jul 31, 2014 11:24 am |
Marshmaster45
Joined: Sat Nov 26, 2011 5:01 pm Posts: 355 Location: larose,la.
They all look like they line up , I'm sure there's a chance it's electrolysis , but it's a good possibility that each on of them crack coordinates with a weld on the opposite side with the stringers. If when it was welded there was good penetration that ended with a lil pit hole in the stop of the weld , that becomes a weak point over time . Could also cause spider cracks.
Thu Jul 31, 2014 11:45 am |
Will
Good point marsh...
Thu Jul 31, 2014 11:48 am |
tchauvin
Thu Jul 31, 2014 11:55 am |
tchauvin
Thu Jul 31, 2014 11:57 am |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
Marshmaster45
If y'all are having that much trouble with electrolysis putting an anode on your boat will help , theres also a possibilty that if it's eating up as quick as some of you say that your aluminum may not be marine grade. I had an aluminum boat that my dad an I built 28yrs ago that when I sold it had some electrolysis but not that bad and two spiders cracks right opposite of welds on the bottom. Really don't think electrolysis is the culprit of cracks.
Thu Jul 31, 2014 12:30 pm |
Frog
Thu Jul 31, 2014 1:51 pm |
DeoVindice
Joined: Thu May 02, 2013 10:45 am Posts: 228 Location: South Alabama
Thu Jul 31, 2014 8:29 pm |
DeoVindice
Thu Jul 31, 2014 8:30 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
Electrolysis doesn't make cracks it makes holes. Hard to tell in the photos but is it holes or cracks?
Mon Aug 04, 2014 8:50 pm |
kibb
I'm with Marsh on this one.
Mon Aug 04, 2014 9:16 pm |
