It is currently Sun Jul 06, 2025 1:29 am
Reply to topic  [ 30 posts ]
 spider cracks in hull
Post spider cracks in hull
Got a guy who wrote to me about spider cracks in his hull. Wanted to know if gg would help. I told him no. He sent me pic and the hull doesn't look like it got a dent in it. He says he does not run it hard and its obvious. the bottom is 1/8 5086. Any of you see or dealt with this?
http://www.gatorglide.com/
gatorheads@comcast.net
Thu Jul 31, 2014 9:07 am
Post Re: spider cracks in hull
Electrolysis can causing pitting leading to cracks, can't tell by the picture but that would be my first guess.
Thu Jul 31, 2014 9:23 am
Tell him to quit shocking fish. I was told this can happen. Lol
1754 GTB / 35 GTR
Thu Jul 31, 2014 9:32 am
Electrolysis?
Thu Jul 31, 2014 9:33 am
That was My first thoughts but says he's got a battery switch and you can see the boat doesn't set in the water much. How would you fix it?
Thu Jul 31, 2014 9:41 am
My boat was 1yr old when i did my Gator glide....
When i lifted it off the trailer everywhere it sat on a bunk board it was ate up and worm holed from electrolosis.
I was explained that this is caused by the copper content in the treated bunk boards reacting with the aluminum....Even where my boards are bolted to the trailer its corroded pretty bad!!!
Thu Jul 31, 2014 9:43 am
Use cypress boards. So they don't rot and u won't have to worry about the chemicals.
Thu Jul 31, 2014 9:52 am
Thu Jul 31, 2014 9:54 am
Thu Jul 31, 2014 9:56 am
Yep,,,im fixing to go get some here soon. I was given an old Hay Barn built from 1x12'' cypress planks and 2x4 studs...I will be using it in my house. So will defenatly use that on the boat trailer.
I wasnt a happy camper to see that fairly new hull looking that way. Luckily it wasnt all the way though....The gator glide filled it in nicely.
Thu Jul 31, 2014 10:00 am
Mostly salt water?
Thu Jul 31, 2014 10:01 am
I have to jack my own thread and say "another reason to have GatorGlide on the bottom :!: " :D
Thu Jul 31, 2014 10:05 am
Any chance he has an onboard charger?
Thu Jul 31, 2014 10:07 am
Cant see under his bunks, but the bottom where the cracks are it don't look that pitted. Did the PT buck thing cause electrolysis or was it acidic? Don't know about an on board charger yet but he did run a Honda generator with rubber mount but it would have powered lights. I would think it would take a lot of bow fishing to do that and the bottom wear doen't show that.
Once he resolves the why, How would you repair this? Just drill and weld I would guess. I'm not a welder but would guess if the metal was that punky from electrolysis the welder would know right away!
Thu Jul 31, 2014 10:35 am
Thu Jul 31, 2014 10:56 am
Also, when he was running the genny and lights, everything needs to go back to the genny and be isolated, dont use the hull as a ground/neutral...
Thu Jul 31, 2014 10:58 am
Thu Jul 31, 2014 11:01 am
Thu Jul 31, 2014 11:24 am
They all look like they line up , I'm sure there's a chance it's electrolysis , but it's a good possibility that each on of them crack coordinates with a weld on the opposite side with the stringers. If when it was welded there was good penetration that ended with a lil pit hole in the stop of the weld , that becomes a weak point over time . Could also cause spider cracks.
Thu Jul 31, 2014 11:45 am
Good point marsh...
Thu Jul 31, 2014 11:48 am
Thu Jul 31, 2014 11:55 am
Thu Jul 31, 2014 11:57 am
If y'all are having that much trouble with electrolysis putting an anode on your boat will help , theres also a possibilty that if it's eating up as quick as some of you say that your aluminum may not be marine grade. I had an aluminum boat that my dad an I built 28yrs ago that when I sold it had some electrolysis but not that bad and two spiders cracks right opposite of welds on the bottom. Really don't think electrolysis is the culprit of cracks.
Thu Jul 31, 2014 12:30 pm
Thu Jul 31, 2014 1:51 pm
Thu Jul 31, 2014 8:29 pm
Thu Jul 31, 2014 8:30 pm
Electrolysis doesn't make cracks it makes holes. Hard to tell in the photos but is it holes or cracks?
Mon Aug 04, 2014 8:50 pm
I'm with Marsh on this one.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Aug 04, 2014 9:16 pm
Users browsing this forum: Majestic-12 [Bot] and 126 guests
