It is currently Mon Jun 30, 2025 10:29 am
Reply to topic  [ 22 posts ]
 Performance Question 35hp
Post Performance Question 35hp
My recently acquired1644 gatortrax and 35 gdsd are running well but not putting out the speeds I thought they would. WOT running close to 3800 rpms, smooth deep water and according to my speed tracker I'm doing top speeds of 24. Motor has no mods, tried different trim positions, running a three blade prop.
This is just me in the boat with gas battery and a few misc items that add no weight really that would affect performance.
Is this all I can expect? :?: It doesn't have a hunt deck.
Hours on motor 136
Thanks for the responses.
Fri Sep 12, 2014 4:00 pm
Post Re: Performance Question 35hp
Prop may be worn.
Fri Sep 12, 2014 9:26 pm
Can you tell if I post a pic? I'm not sure how to tell. Thanks for the reply.
Sat Sep 13, 2014 1:42 am
Take a tape measure and measure from center of the prop to the tip of each blade, should all be about the same. Post that measurement here along with a good pic or two of the prop, and someone will give you a legit answer.
Sat Sep 13, 2014 3:26 am
Thanks for the reply Russ, will do.
Sat Sep 13, 2014 4:00 am
Measured from center to tip of each blade and they all appear to measure about 5.5 inches. Below are some pics of the blade. Not sure how old it is.
Three blade came with the motor.
There's not a lot of cupping around the edges of the blades. Should there be.
Sat Sep 13, 2014 10:36 am
Took it out today. Me, wife and our daughter who is 6 and wot was turning 3700 rpms. Doing 21 bumping 22. Scratching my head on this one. I really have to bare down and squeeze the throttle to get it to 3700. Idle rpms are 900 in the water.
Perhaps not full cable travel? Maybe an idle adjustments needed?
Thanks.
Sun Sep 14, 2014 4:04 pm
Is your carb opening up all the way? what are your out of water rpms?
Tue Sep 16, 2014 1:16 pm
Tue Sep 16, 2014 6:59 pm
What does the bottom of the boat look like?
Tue Sep 16, 2014 7:17 pm
Tue Sep 16, 2014 7:20 pm
I would start with the throttle cable and work from there. Make sure you butterfly valve is opening all the way. You prop does show a little wear but a worn prop normally results in more Rpms because of less cup and actual prop. I also beileve that gdsd tend to try and ride high/blow the prop out if the water when the prop wears down(don't quote me but that's why there is a tab to bend on the side of the skeg)
Tue Sep 16, 2014 7:28 pm
Once you make sure your carb is opening up all the way just check that the tab the throttle linkage hooks up to bottoms out against the throttle stop. At 130 hours your heads prob have some leakage that doesnt help your speed
Tue Sep 16, 2014 7:58 pm
Any dealers or guys that know how to give it a look close to my location? Located in Jackson County, FL an hour west of Tallahassee.
Wed Sep 17, 2014 5:54 pm
Weight plays a big factor. Especially in a round chine Gator trax hull. I know cause I have one. What you gain in handling (turning ablility) you lose in some speed. Probably 2-3mph. My 18x44 hull has 2 gun boxes and a large bench compartment . 2 batteries, 50lb troll motor plus gear like 3 spot lights, paddle, push pole, trailer jack, tools etc. I run a 35 mud buddy with aftermarket exhaust and big blade prop. I'll run 25.5 to 26.4 mph at 3950 rpms I weigh 175lbs. With my son 180lbs I get 24mph at 3900 rpms with both of us. Add 2 more guys and we are down to 22-23mph at 3770rpms. The 16ft boat does not carry the load as well as the 18ft in the same hull width. My buddy has the 16x44 gator trax with all stock mud buddy and I think he runs 25mph by himself. That's just what they do. Wind and current play a factor also.
18x44 Gator Trax, Stage 2 Mudbuddy
Wed Sep 24, 2014 5:10 pm
Just check with my buddy with the 16x44, he gets 24 mph tops
Wed Sep 24, 2014 5:41 pm
Once you get weight and trim figured out you might pick up a couple, my gtr is on a 1642 and I average 26
1754 excel F86 44HDR
Wed Sep 24, 2014 7:30 pm
Thanks for the replies fellas. I adjusted the trim tabs and it's running better. 2 guys and gear hitting 24 so I'm happy.
Thanks again everyone for chiming in.
Wed Sep 24, 2014 7:41 pm
Good deal. With 2 guys and a dog doing 24 that's about the best you'll do. Everything is working properly.
Thu Sep 25, 2014 2:53 am
That's what I was getting out of my 1860 gd w/ a 35 gdsd on the back. If you're gonna keep the motor, I would definitely invest in a Mikuni carb. There's something off though.
Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha
Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Mon Nov 03, 2014 9:25 am
Tue Nov 04, 2014 5:17 am
Tue Nov 04, 2014 7:36 am
Users browsing this forum: No registered users and 110 guests
