It is currently Tue Jul 01, 2025 12:11 pm
Reply to topic  [ 22 posts ]
 bending hat channel
Post bending hat channel
do i need a bender to bend .090 or .100 hat or could i just weld one end and bend with hull?
Sun Nov 23, 2014 7:27 pm
Post Re: bending hat channel
nobody uses hat channel?
Mon Nov 24, 2014 11:45 am
I know instagator911 on here uses them, pm him and see how he does it.
Mon Nov 24, 2014 12:32 pm
I guess you using it for your stringers?
I uses square tubing and where my rake is I use a skill saw and cut a relief cut about every 6" about half way through it to make it easy to bend and weld to the floor. I then weld the reliefs up.
Mon Nov 24, 2014 1:52 pm
I think instagator uses a tubing roller and rolls a bend first.
Mon Nov 24, 2014 1:54 pm
That would be the best way but you would have to be careful not to squeeze it flat.
What do you have against rectangle tubing or square tubing?
Sent from my beeper
Mon Nov 24, 2014 5:27 pm
Jay Dore
Tue Nov 25, 2014 6:20 pm
Wed Nov 26, 2014 3:43 pm
Wed Nov 26, 2014 4:00 pm
Wed Nov 26, 2014 5:03 pm
Wed Nov 26, 2014 5:05 pm
Wed Nov 26, 2014 6:13 pm
I used hat section when I built my rig. I used a hand roller that I have and it worked great.
Wed Nov 26, 2014 7:51 pm
Why didn't you run them the full length of the bottom?
Sent from my beeper
Wed Nov 26, 2014 10:06 pm
Wed Nov 26, 2014 10:16 pm
Thu Nov 27, 2014 7:57 am
Thu Nov 27, 2014 8:52 am
Hard to have true dry storage in an aluminum boat, condensation and all. I've seen some messed up boats with hooks and cracks where people welded the front wall to the bottom of the boat. Just not a fan of it
Thu Nov 27, 2014 9:04 am
Thu Nov 27, 2014 9:39 am
Thu Nov 27, 2014 9:59 am
You got it. And that's seal welded also to floor. I've had good success with this way. It's actually broke out so I only have to weld it to floor and stitch to ribs.
Thu Nov 27, 2014 10:15 am
I weld my stringers to my vertical transome channel and all the way to the nose 3" pipe which is welded to the gunwale. Then the motors leverage is tied from front to back and connected to the gunwale. I also figure it strengthens the nose in case of collision.
Thu Nov 27, 2014 12:21 pm
Users browsing this forum: Google [Bot] and 141 guests
