It is currently Fri Jun 27, 2025 5:47 pm
[ 8 posts ] |
waggman
 Boat slide?
Will an outboard with prop have less / prevent sliding on a mud motor smooth bottom hull?
Tue Oct 06, 2015 8:54 am |
BlueShamu
 Re: Boat slide?
No.
Tue Oct 06, 2015 10:07 am |
Frog
 Re: Boat slide?
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Tue Oct 06, 2015 3:57 pm |
KJH
Joined: Tue Jun 09, 2009 9:09 pm Posts: 520 Location: Nebraska
 Re: Boat slide?
I have a smooth bottom mud hull (1852). I go back and forth between a 35GTR and a 60hp tiller outboard depending on what I'm doing. Although the boat was built for the mudmotor it handles great with the outboard once I got the motor height right. It doesn't slide much at all even if I turn when really hauling ass with the outboard. I suppose if I really drove it recklessly, I could get it to slide bad with the outboard.
It doesn't slide too bad with the MM either, but it does slide when I make sharp turns while cruising the backwaters at high speed.
_________________ 1854 Brother Breaux and Boss 40XP and 90hp outboard.
Thu Oct 22, 2015 11:35 am |
deadbird8
 Re: Boat slide?
Chine design affects the sliding, not the flat bottom. Round chines or multi-taper will stick better at speed than a square chine.
Mon Nov 02, 2015 6:26 am |
Frog
 Re: Boat slide?
Mon Nov 02, 2015 7:05 pm |
deadbird8
 Re: Boat slide?
Wed Nov 04, 2015 6:26 am |
Frog
 Re: Boat slide?
not to mention the outboard is acting as a deeper rudder with a prop that is pulling your stern around. As apposed to a surface prop pushing you with almost no rudder or skeg in the water.
Wed Nov 04, 2015 1:43 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 88 guests |
