It is currently Sat Jul 12, 2025 12:01 am
[ 7 posts ] |
carl
Joined: Wed May 01, 2013 5:58 pm Posts: 4 Location: north carolina
 stubborn prop
how do i get stubborn prop off a 25hp mudd buddy bought the flat bar and 15" cresant but man that thing wont budge
Wed May 01, 2013 6:35 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: stubborn prop
Why two different threads
Wed May 01, 2013 6:37 pm |
GBB
Joined: Tue Dec 28, 2010 10:04 am Posts: 28 Location: Georgia
 Re: stubborn prop
Cut it off.
Mon May 06, 2013 7:57 am |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
 Re: stubborn prop
Get a big 1/2" drive socket and cut it to fit over the hub and grab the blade and use an impact to get that bitch off.
Fri May 10, 2013 5:36 pm |
SCSuperfly
 Re: stubborn prop
Which MB? Sure it's not a hex?
_________________ Modded 36 PD draggin' around an 1848 PD boat backwards!
Sat May 11, 2013 3:21 pm |
fireman1293
 Re: stubborn prop
Here's a thought. Thread on a nut behind your prop, weld it to the prop. Soak the living crap out of it with PB blaster or equivalent. Then take an impact socket to the nut and try to spin it off. That way if it breaks loose you can cut off the nut and reuse the prop. Good luck
Sat May 11, 2013 6:47 pm |
instagator911
Joined: Sat Dec 05, 2009 12:36 pm Posts: 1127 Location: Behind the hood next 2 da bright light! SETX
 Re: stubborn prop
heat the prop hub with out heating the shaft. move prop till it starts 2 grab again then reheat prop. if shaft gets hot, stop and let cool. repeat till prop comes off.
_________________ Jay Dore
Sun May 12, 2013 12:27 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 56 guests |
