It is currently Sat Jul 12, 2025 9:36 am
Reply to topic  [ 7 posts ]
 stubborn prop
Post stubborn prop
how do i get stubborn prop off a 25hp mudd buddy bought the flat bar and 15" cresant but man that thing wont budge
Wed May 01, 2013 6:35 pm
Post Re: stubborn prop
Why two different threads
Wed May 01, 2013 6:37 pm
Cut it off.
Mon May 06, 2013 7:57 am
Get a big 1/2" drive socket and cut it to fit over the hub and grab the blade and use an impact to get that bitch off.
Fri May 10, 2013 5:36 pm
Which MB? Sure it's not a hex?
Modded 36 PD draggin' around an 1848 PD boat backwards!
Sat May 11, 2013 3:21 pm
Here's a thought. Thread on a nut behind your prop, weld it to the prop. Soak the living crap out of it with PB blaster or equivalent. Then take an impact socket to the nut and try to spin it off. That way if it breaks loose you can cut off the nut and reuse the prop. Good luck
Sat May 11, 2013 6:47 pm
heat the prop hub with out heating the shaft. move prop till it starts 2 grab again then reheat prop. if shaft gets hot, stop and let cool. repeat till prop comes off.
Jay Dore
Sun May 12, 2013 12:27 am
Users browsing this forum: No registered users and 61 guests
