It is currently Wed Jul 09, 2025 10:16 pm
[ 5 posts ] |
Echocaller93
Joined: Mon Aug 12, 2013 11:03 am Posts: 66 Location: Arkansas
 2001 Mercury 25hp tiller
Been having problems with it not wanting to shift into reverse. Shifts smoothly into forward but about 80% of the time it won't go into reverse. When I have to go to reverse, I have to pull the motor out of the water (not running) and turn the prop while shifting the tiller into reverse. Then drop the motor back in the water and go to neutral, start it, and it'll go into reverse like it's supposed to. Then you run down the river or idle a little ways and try to go into reverse and it won't go. Then I have to repeat the process.
Any ideas??
Thu Sep 12, 2013 4:58 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Re: 2001 Mercury 25hp tiller
Sounds like a linkage problem. Check all adjustments and linkage rod
_________________ 23 swomp/ 1542 tracker
Fri Sep 13, 2013 8:54 am |
Echocaller93
I've gone thorough all the linkages. I changed out the carrier bearing in the lower unit since the one that was in it was in rough shape. I'm thinking something in the lower unit is not lining up the go into gear..
Fri Sep 13, 2013 10:14 am |
Trousertrout
Any noise when you try to go into reverse?
Fri Sep 13, 2013 11:11 am |
Echocaller93
Nope, no noise at all.
Mon Sep 16, 2013 7:45 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 23 guests |
