It is currently Wed Jul 09, 2025 8:30 pm
Reply to topic  [ 5 posts ]
 2001 Mercury 25hp tiller
Post 2001 Mercury 25hp tiller
Been having problems with it not wanting to shift into reverse. Shifts smoothly into forward but about 80% of the time it won't go into reverse. When I have to go to reverse, I have to pull the motor out of the water (not running) and turn the prop while shifting the tiller into reverse. Then drop the motor back in the water and go to neutral, start it, and it'll go into reverse like it's supposed to. Then you run down the river or idle a little ways and try to go into reverse and it won't go. Then I have to repeat the process.
Any ideas??
Thu Sep 12, 2013 4:58 pm
Post Re: 2001 Mercury 25hp tiller
Sounds like a linkage problem. Check all adjustments and linkage rod
23 swomp/ 1542 tracker
Fri Sep 13, 2013 8:54 am
I've gone thorough all the linkages. I changed out the carrier bearing in the lower unit since the one that was in it was in rough shape. I'm thinking something in the lower unit is not lining up the go into gear..
Fri Sep 13, 2013 10:14 am
Any noise when you try to go into reverse?
Fri Sep 13, 2013 11:11 am
Nope, no noise at all.
Mon Sep 16, 2013 7:45 am
Users browsing this forum: No registered users and 56 guests
