It is currently Mon Jul 07, 2025 7:19 am
Reply to topic  [ 13 posts ]
 GTR shaft removal?
Post GTR shaft removal?
Are y'all having to loosen the engine mount bolts and temp shim motor to allow enough play in the belt to get the shaft housing out?
1944 skiff with 35 GTR
Sat Jan 25, 2014 9:25 am
I find it easier to pull reverse and transmission and just slip off belt on top. Therefore it's easy to reset bottom when re installing
Sat Jan 25, 2014 9:41 am
X2 but yes still loosen motor mounts don't have to loosen a whole lot at all
Sent from my iPhone using
Sat Jan 25, 2014 9:49 am
Post Re: GTR shaft removal?
Ok thanks for the info
Sat Jan 25, 2014 9:50 am
Another question.....
What am I missing here, trying to pull the lower belt gear off so I can access the bearing and seals. I have removed the allen bolts and she is not budging.
Any tips would be appreciated before I start beating it with a hammer. Thanks!
Sun Jan 26, 2014 12:11 pm
Did u screw the Allen bolt In the opposite hole to
Push the gear off the taper lock?
Sun Jan 26, 2014 12:13 pm
Then get a hammer
Sun Jan 26, 2014 12:14 pm
Nope i didnt, thanks dfou got it now
Sun Jan 26, 2014 12:29 pm
Make sure u use a rubber mallet that gear is aluminum
Sun Jan 26, 2014 12:42 pm
Ok got the gear, race, and the snap ring out the way....now fighting with the seal
Sun Jan 26, 2014 1:09 pm
Alright got the lower unit back together and ready to put back on. Just need to pull tran/rotor for belt slack and really not sure how...do i start with removing the bolt in center of rotor?
Sun Jan 26, 2014 2:40 pm
Center bolt comes out, pull planetary out then five or six Allen heads to remove other section of planetary, pull belt off. Locktite during reassembly
Sent from my shitty cell
Sun Jan 26, 2014 3:22 pm
Thank you
Sun Jan 26, 2014 3:45 pm
Users browsing this forum: No registered users and 49 guests
