It is currently Wed Jul 16, 2025 3:07 am
Reply to topic  [ 7 posts ]
 homemade small surface drive
Post homemade small surface drive
First off, idk if this is the right forum, new to the site, well first post new! Ive decided to take the plunge to build a surface drive, now i know they have ones for next to nothing and most people might say dont waste your time buy one. But its been a good experience so far just understanding how there work. At any rate the motor is a 13 hp hf motor, im building the frame to accept a larger motor if i ever find a good deal. So far i have built the shaft housing, cut it up and redoing it, the box and transom mount is built. Im running belt drive, dont have wnough patience to fool with the chain. With that being said here she is
35 GTR chasin a BBC 1848
Sun Oct 14, 2012 5:54 pm
Post Re: homemade small surface drive
And the transom mount. With manual trim, i left enough room to add electric later if i want.
Sun Oct 14, 2012 5:56 pm
good looking job. where did you get belt pulley?
Sun Oct 14, 2012 6:37 pm
Thanks, all my parts came from mcmaster carr, the top pully is a 32 tooth and the bottom is a 44.
Sun Oct 14, 2012 6:43 pm
can you give part #s and shaft sizes thanks.. I am building 22 hp LT belt drive
Tue Oct 16, 2012 9:16 pm
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Wed Oct 17, 2012 5:53 am
Built several standard LT. No clutch but will have some gear reduction. Have not worked out ratio I will go with. The way I am going to build it should be less work and welding and I will be able to go from small block to big block without a big hassel. Thanks for any info. Still in the planning stage.
Wed Oct 17, 2012 6:36 pm
Users browsing this forum: No registered users and 33 guests
