It is currently Wed Jul 09, 2025 12:18 pm
Reply to topic  [ 14 posts ]
 Driveshaft- 4130 vs stressproof 1144
Post Driveshaft- 4130 vs stressproof 1144
Sorry this is not a super fun topic with pics. Making a new and stronger driveshaft for my surface drive. Standard cold rolled is too soft, anyone recommend one over the other between 4130 and 1144 stressproof.
Mon May 20, 2013 11:21 pm
Post Re: Driveshaft- 4130 vs stressproof 1144
18-4 would be way better
Tue May 21, 2013 4:06 am
17-4 Stainless Boat Shafting
17-4 PH condition H1150
Straightened, ground and polished to boat shaft specs.
Aluminum and Stainless in Broussard, La or New Orleans, La.
Tue May 21, 2013 4:59 am
I would use PH-17 (aqua met 17)
Tue May 21, 2013 5:42 am
Where r u located?
Tue May 21, 2013 6:24 am
Hi, I'm up in ny.
I was quoted $117 for my part in 4130, this is for a 11hp surface drive running at 6k rpm. It's a Briggs animal so the rpm level is fairly low. Do I really need a hardened shaft for that application? I had my cold rolled shaft split right where the 3/4" bearing race meets the 1" shaft. At the time I may have been over reving to like 8k but now have a 6k rev limiter. This isn't for a gtr or prodrive, I don't want to spend over $200 on the shaft.
Tue May 21, 2013 11:56 am
Well lets see, u already cracked a cold rolled shaft, do u really need a hardened shaft for ur application?
Tue May 21, 2013 2:22 pm
I'm not having any luck finding a local shop that can make a hardened and balanced stainless shaft. I just emailed hill marine for any suggestions, please anyone else let me know any shop that makes prop shafts. All the ones in my area don't heat treat and grind.
Wed May 22, 2013 12:24 am
Pm me I know a guy but he's way south. He has what u need ill give u his number but ur gonna have to see if he will ship it. That I don't know.
Wed May 22, 2013 10:46 pm
Buy 4140 pre hard turned ground and polished. Speedy metals has it 3/4" X 48" for about $30.
17-4 H1150 is also good, but is typically oversized for running through a .750" bore bearing and will require a light pass on a lathe
Mag10
Fri May 24, 2013 11:17 am
Super Duplex or Inconel 625
Fri May 24, 2013 8:11 pm
Fri May 24, 2013 9:04 pm
Sat May 25, 2013 6:47 am
I would look at why it cracked. I build a 16hp surface drive with ¾ cold rolled steel shaft and a 10x8 prop and the engine has the governor removed so it will free spin until the valves start to float (7k +) and I have not had a problem running it. Ran through mud and rocks all last season and the only wear is on the prop which took a beating.
Just my 2 cents
Fri May 31, 2013 3:44 pm
Users browsing this forum: No registered users and 40 guests
