It is currently Tue Jul 15, 2025 1:22 am
Reply to topic  [ 7 posts ]
 PD lower unit question
Post PD lower unit question
While getting my LU ready for the 3 piece seal I got to thinking. The question is how else can water enter the LU?
Mine is not cracked and I'm changing the seal but when running the boat I do see water hit the vinyl cover covering the clutch. It might be me backing off the throttle or another boats wake hitting me while drifting for Fluke. There must be a seal on the upper end under the clutch. My 36 PD is a 2007 with low hours and manual reverse.
Thanks much for any thoughts,
Old Wayne
Wed Jul 10, 2013 7:45 am
Post Re: PD lower unit question
Yep, there's a seal in the upper end and if I'm not mistaken your motor has a vent in the top of the upper shaft. They discovered it's not needed and you can plug it.
Wed Jul 10, 2013 7:50 am
Wed Jul 10, 2013 11:09 am
You have to pull the power head off of the lower unit to see that vent. And yes on your year motor you have it. And yes water can get in there especially on short shaft units.
Wed Jul 10, 2013 11:14 am
Mine is an 07'. When I pulled my power head to do a little work, I had a bolt looking thing in mine.
When I seperated the lower unit from the power head, this fell out. Like Will mentioned, it was a vent of some sort. I didn't install it back, because it really didn't connect to anything. Nor did I notice a vent hole on the lower unit to plug up. So far so good, I guess if I start noticing water of wartered grease near my clutch, I'll know it was meant for something.
Wed Jul 10, 2013 11:22 am
Bart at FSE said I could remove it. Still haven't yet. Mine is a rubber hose about 4 inches.
Wed Jul 10, 2013 12:53 pm
Heres one with the rubber hose sticking out the topImageUploadedByTapatalk1373484905.780955.jpg
Wed Jul 10, 2013 1:35 pm
Users browsing this forum: Google [Bot] and 35 guests
