It is currently Wed Jul 16, 2025 6:44 am
Reply to topic  [ 8 posts ]
 Prodrive Lower Unit Removal
Post Prodrive Lower Unit Removal
Hey guys - I need some help with dropping the lower unit on my 09 Prodrive. I want to take it out and give everything a good cleaning and remove all the gunk before the start of duck season but I don't know where to start. I have searched all over but can't find any write ups or photos on the removal process. Any guidance you could give me would be much appreciated. Step by step pictures would be even more appreciated.
I am pretty mechanical but when it comes to these motors I am still pretty green.
Also, should I order new bushings/seals before I tear into it and just replace everything while I am in there or can I just take it out give it a good once over and put everything back. I don't have any leaking issues yet...
Sun Jul 28, 2013 8:43 am
Post Re: Prodrive Lower Unit Removal
gotta take the engine off the frame... take the clutch off...
shaft coupling
and i think its 6 bolts around the shaft to take out then it will drop out....
its not hard
I gave up mud motors
Sun Jul 28, 2013 11:02 am
Just to clarify, as I understand it, the engine/clutch/spline coupler comes off as one piece with a plate of metal sandwhiched in the middle. Just unbolt the big 4 bolts holding the engine to the frame and anything else holding it down and it alls pulls off. Sometimes takes some persuasion. I have never done this but I have talked to kp on the phone with it. Just call pro drive and ask for pech. He will explain it thoroughly very quickly.
Tue Jul 30, 2013 7:03 pm
No doubt, Peck will walk you threw a maintenance problem over the phone like he was standing over your shoulder.
Sent using Morse Code from my not so smart phone.
Tue Jul 30, 2013 8:26 pm
Wed Jul 31, 2013 5:00 am
Wed Jul 31, 2013 5:11 am
You don't have to pull the coupler off the clutch to drop the LU, I just threw those pics up there as well. The LU will literally fall out when you get the last bolt out, have something under it....Have fun and prepare to get a little grease on you! hahaha
Wed Jul 31, 2013 5:14 am
Tighten down on the tension knob and it wont fall out when you undo the 6 bolts.
Wed Jul 31, 2013 7:32 am
Users browsing this forum: No registered users and 29 guests
