It is currently Tue Jul 15, 2025 7:27 am
Reply to topic  [ 25 posts ]
 mudbuddy triim problem
Post mudbuddy triim problem
hey guys I got 2010 23 mb hd sport. My trim was working fine, a little slow coming up but working. Now i have nothing no clicks or anything. Does this model have relays or fuses? What is the best way to test? I have checked wires at trim unit and switch they seem to be fine. Any help would be much appreciated.
35 Mud buddy Stage 2 on a 1844 Uncle J
Wed Jul 24, 2013 6:26 pm
Post Re: mudbuddy triim problem
My trim switch went bad but mine would move just clocked alot. I think they have relays but you may want to til one of the gurus chimes in.
''It's just 90 foot you're gonna die if you fall 20 foot so whats another 70 foot'' Jason Humble climbing school 12'
Wed Jul 24, 2013 7:42 pm
4500 black death with a little more in it strapped to a 1848 wc custom
Wed Jul 24, 2013 9:34 pm
Pull the stainless plate off the transom bracket (says Sport on it)& check the relays.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 24, 2013 11:22 pm
Really tcamo !!!!!
Too soon man too soon
Thu Jul 25, 2013 4:54 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 25, 2013 5:49 am
My relays are not under that stainless bracket
Thu Jul 25, 2013 7:03 am
Merc trim, or Thompson? Merc trim relays are under there, Thompson has no relays. Pretty sure MB started using Merc in late 09, all 2010 should have it (except mini frames)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 25, 2013 7:05 am
Same here. Are the relays the small yellow boxes on the side of motor are they both for trim? Or is one of them for the clutch?
Thu Jul 25, 2013 7:07 am
I just had to replace my whole trim switch on the handle. One of the contacts on the inside had come loose and broke in half somehow in there. Check all your connections on the breakers that are next to the starter and make sure your getting a good connection at the switch its self.
2015 1748 gator tail with drop deck. 2015 35 GTR :
Thu Jul 25, 2013 7:12 am
Those are circuit breakers, not relays. Yes 1 for clutch & 1 for trim.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 25, 2013 7:13 am
OK THx. I will check the circuit breaker. Is it OK to jump to test.
Thu Jul 25, 2013 7:19 am
Yep
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 25, 2013 7:21 am
hey guys I have done some investigation. My switch and breakers are good. I am getting power to the wires at the motor when I push the switch. Does that mean the motor is bad? Are there connections inside motor that can be burnt or loose? Where do I go from here?
Fri Jul 26, 2013 6:33 am
Pull the trim off and touch the wires to a battery and see if it moves if not ya may need a new one.
Fri Jul 26, 2013 6:50 am
Did you check the relays under the Sport plate, or do you have Thompson trim?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Jul 26, 2013 7:44 am
its a thompson trim I believe. There are no relays on under the plate. All the numbers and info is worn off the motor any idea of a model number where I can get a new one?
Fri Jul 26, 2013 8:19 am
Pic of it? Boat Dr for replacement
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Jul 26, 2013 9:13 am
Talked to boat Dr. Got a few more things to check but looks like replacement.
Fri Jul 26, 2013 10:09 am
OK guys I have gotten the unit off. Hooked it directly to power and I get nothing. Pulled apart and found the problem. The electric motor was pretty burnt up. The unit is a bear unit. I was told you can get a replacement st motion industries is this true? Or Is mud Buddy the only place to order. I will attach some pics of motor.
Sat Jul 27, 2013 12:52 pm
MI might have one, but you can order a Thompson from Boat Dr for about $280-300
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jul 27, 2013 6:00 pm
Well I bit the bullet and ordered one from mud buddy. I tried boat dr. did not have one in stock and referred me to mb.
Tue Jul 30, 2013 1:25 pm
Hey camo while I'm working on the motor my starter solenoid has been acting up. Sometimes it clicks sometimes it cranks? Is that a part that is pretty generic? Can I get it at my local lawnmower shop?
Wed Jul 31, 2013 6:24 am
I'm not 100% positive, but I think a Ford solenoid is compatible with the 23. Just bring it with you to the parts house and tell em it's on a lawn mower.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 31, 2013 6:51 am
Just a little info for everybody you can get the solenoids from napa for $16.
Fri Aug 02, 2013 8:24 am
Users browsing this forum: No registered users and 33 guests
