It is currently Sat Jul 12, 2025 9:01 am
Reply to topic  [ 5 posts ]
 scavenger motor prop question
Post scavenger motor prop question
I have a 13hp Honda scavenger, done some motor upgrades and want it to run a little better than it did. Seen some people talking about a calvataion plate and moving it. Now the problem is which way. Do I open the plate up to allow more water to hit the prop or close it to funnel the water across it. I talked to the owner and he said I have the old design and can buy a new one for 175$. I'm trying to avoid spending that cause the old lady is already mad about my duck hunting spending. Any help would be appreciated.
Wed Sep 04, 2013 11:30 am
Post Re: scavenger motor prop question
If you are going to have to spend any money on it at all sell it and buy a go devil or mudbuddy long tail. Or any other brand.
Wed Sep 04, 2013 5:14 pm
Yea that's what I've heard... but $$$ is in short supply with the 4 month old at home
Wed Sep 04, 2013 6:02 pm
The scavenger is going to be a money pit either way you look at it, the design is limited, if it wasn't all of the longtails would be built with the PTO facing backwards. The best thing you can do is adjust the cavitation plate so it skims just under the surface of the water. Bending the plate down lets water to flow over the plate causing lift, bending up causes water to have to flow over the plate at a steeper angle pushing the plate down.
1436 Lowe
Thu Sep 05, 2013 1:14 am
Ok thanks. I'm gonna mess around with it and see if opening it up helps at all. This will proly b the last year running it.
Thu Sep 05, 2013 6:12 am
Users browsing this forum: No registered users and 50 guests
