It is currently Tue Jul 08, 2025 10:51 am
[ 7 posts ] |
How to know if GTR35 rear seal is bad?
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
How can you tell if the rear seal (one by the prop) on a GTR 35 is bad??
I was backing the trailer into the garage, went a little too far hit a bike rack/drywall. Fuckin' dumb ass!!!!!!! Made a good sized hole in the drywall. The end of the prop shaft has a little drywall dust. Other than that no visible damage. I took the prop off and the shaft had some grease on it (probably leaves factory like that?). Wiped it off with a paper towel.
I turned it on and when to full throttle (in gear). Is it normal to just have a tiny bit of grease on the prop shaft by the rear seal? How will I know if something is damaged?
Thanks.
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Sun Sep 08, 2013 6:18 pm |
krogers
Joined: Fri Oct 29, 2010 8:24 am Posts: 1958 Location: Bristol, FL
 Re: How to know if GTR35 rear seal is bad?
That sumbitch better be tougher than a Sheetrock wall!
_________________ 1754 GTB / 35 GTR
Sun Sep 08, 2013 6:21 pm |
MNGunner
Sun Sep 08, 2013 6:26 pm |
deltaduckmaster
You don't blow the seal by not taking out the screw. It's a backwards seal so you can't blow it. Put some hours on it I'm sure nothing is wrong. Pump some grease in it if it has water in the grease then maybe it's bad. I would be more worried about bending the shaft or prop. Put it in gear on the trailer make sure it's balanced
Sun Sep 08, 2013 6:49 pm |
MNGunner
Sun Sep 08, 2013 7:02 pm |
Wildberry
Joined: Sun Apr 22, 2012 6:17 pm Posts: 1018 Location: DA HAVEN FL,
Sorry to hear that about your Cuzz
_________________ EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Sun Sep 08, 2013 7:13 pm |
MNGunner
Sun Sep 08, 2013 7:16 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 47 guests |
