It is currently Tue Jul 08, 2025 5:12 pm
Reply to topic  [ 7 posts ]
 How to know if GTR35 rear seal is bad?
Post How to know if GTR35 rear seal is bad?
How can you tell if the rear seal (one by the prop) on a GTR 35 is bad??
I was backing the trailer into the garage, went a little too far hit a bike rack/drywall. Fuckin' dumb ass!!!!!!! Made a good sized hole in the drywall. The end of the prop shaft has a little drywall dust. Other than that no visible damage. I took the prop off and the shaft had some grease on it (probably leaves factory like that?). Wiped it off with a paper towel.
I turned it on and when to full throttle (in gear). Is it normal to just have a tiny bit of grease on the prop shaft by the rear seal? How will I know if something is damaged?
Thanks.
Sun Sep 08, 2013 6:18 pm
Post Re: How to know if GTR35 rear seal is bad?
That sumbitch better be tougher than a Sheetrock wall!
1754 GTB / 35 GTR
Sun Sep 08, 2013 6:21 pm
Sun Sep 08, 2013 6:26 pm
You don't blow the seal by not taking out the screw. It's a backwards seal so you can't blow it. Put some hours on it I'm sure nothing is wrong. Pump some grease in it if it has water in the grease then maybe it's bad. I would be more worried about bending the shaft or prop. Put it in gear on the trailer make sure it's balanced
17x48 extreme stage 2 GTR
Sun Sep 08, 2013 6:49 pm
Sun Sep 08, 2013 7:02 pm
Sorry to hear that about your Cuzz
EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Sun Sep 08, 2013 7:13 pm
Sun Sep 08, 2013 7:16 pm
Users browsing this forum: No registered users and 55 guests
