Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Prodrive Skeg Removal
What's the secret to remove the allen head bolts from the skeg? I have like 5 that are stuck. I've bent 3 allen wrenchs trying to get them off. They've been soaking in Kroil for days but it doesn't seem to help. I've thought about heating them (I'm replacing the prop shaft) or an impact wrench but I don't want to screw anything up.
Sat Sep 21, 2013 1:01 am |
BlueShamu
 Re: Prodrive Skeg Removal
Just a thought, try to tighten them and then try to loosen. The may break loose.
The other option, I have those tee handle allen wrenches with a short stub of an allen wrench on the tee handle. Not much to twist. May try to find one of those?
Sent using Morse Code from my not so smart phone.
Sat Sep 21, 2013 4:35 am |
BlueShamu
Like this:
Sat Sep 21, 2013 4:37 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
I went through the same shit and broke one. Ended up buying a 1/4 impact per the advice of bb and that did the trick for me..... And make sure your bit is fully seated in the allen head
_________________ 1850 & 36pd
Sat Sep 21, 2013 5:22 am |
cb5331
I used a small portable impact.
Sat Sep 21, 2013 5:40 am |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
Are you talking about the button bolts that hold the skeg on or the lower shaft housing.
If its the button head bolts a drill and bit work great. I drill them out all the time.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Sat Sep 21, 2013 7:28 am |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
After you drill them out (that what you will end up doing) replace with stainless....Saves you a lot of headache in the long run...I changed mines before i put it in the water.
I have to give props to Gator tail for using stainless in thiers. Just dumb of PD not to.
Sat Sep 21, 2013 7:59 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
plasma torch
_________________ I gave up mud motors
Sat Sep 21, 2013 12:13 pm |
Wilson
Update: Today I went to Sears and got a 3/16th hex head socket (regular version, couldn't find an impact version). Using my impact wrench, it worked on two of the bolts on the shaft housing but then broke when I moved up to the bolts in front of the knuckle. So back to Sears to exchange it out. I'm going to try again with the impact wrench set at a lower pressure.
Sat Sep 21, 2013 1:58 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Lowes has a good assortment of dewalt impact ready products.
Sat Sep 21, 2013 2:04 pm |
Wilson
Yea, I just broke the second one.
Sat Sep 21, 2013 2:48 pm |
Will
Most can't keep them tight, you're lucky
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Sat Sep 21, 2013 2:57 pm |
naj
Sat Sep 21, 2013 3:03 pm |
naj
steinb3rg
Lost a few of mine the third time I took the boat out. To me it seems they are a little short and the end of the bolt was barely touching the nylon in the lock nut. KP sent me some extras but I ended up going to ACE and picking up some stainless Philips head that were a 1/4" longer than the originals. Haven't had any issues since. They stay tight.
_________________ 17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true." "Where'd you hear that?" "The internet"
Sat Sep 21, 2013 4:42 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
On the real stubborn ones. I take a 1/2 brass punch and hammer and ping the nut side 6 or 7 time. Works well.
Sat Sep 21, 2013 8:46 pm |
