It is currently Tue Jul 08, 2025 10:45 pm
Reply to topic  [ 16 posts ]
 Prodrive Skeg Removal
Post Prodrive Skeg Removal
What's the secret to remove the allen head bolts from the skeg? I have like 5 that are stuck. I've bent 3 allen wrenchs trying to get them off. They've been soaking in Kroil for days but it doesn't seem to help. I've thought about heating them (I'm replacing the prop shaft) or an impact wrench but I don't want to screw anything up.
Sat Sep 21, 2013 1:01 am
Post Re: Prodrive Skeg Removal
Just a thought, try to tighten them and then try to loosen. The may break loose.
The other option, I have those tee handle allen wrenches with a short stub of an allen wrench on the tee handle. Not much to twist. May try to find one of those?
Sent using Morse Code from my not so smart phone.
Sat Sep 21, 2013 4:35 am
Like this:
Sat Sep 21, 2013 4:37 am
I went through the same shit and broke one. Ended up buying a 1/4 impact per the advice of bb and that did the trick for me..... And make sure your bit is fully seated in the allen head
1850 & 36pd
Sat Sep 21, 2013 5:22 am
I used a small portable impact.
Sat Sep 21, 2013 5:40 am
Are you talking about the button bolts that hold the skeg on or the lower shaft housing.
If its the button head bolts a drill and bit work great. I drill them out all the time.
Sat Sep 21, 2013 7:28 am
After you drill them out (that what you will end up doing) replace with stainless....Saves you a lot of headache in the long run...I changed mines before i put it in the water.
I have to give props to Gator tail for using stainless in thiers. Just dumb of PD not to.
Sat Sep 21, 2013 7:59 am
plasma torch
I gave up mud motors
Sat Sep 21, 2013 12:13 pm
Update: Today I went to Sears and got a 3/16th hex head socket (regular version, couldn't find an impact version). Using my impact wrench, it worked on two of the bolts on the shaft housing but then broke when I moved up to the bolts in front of the knuckle. So back to Sears to exchange it out. I'm going to try again with the impact wrench set at a lower pressure.
Sat Sep 21, 2013 1:58 pm
Lowes has a good assortment of dewalt impact ready products.
Sat Sep 21, 2013 2:04 pm
Yea, I just broke the second one.
Sat Sep 21, 2013 2:48 pm
Most can't keep them tight, you're lucky :lol:
Sat Sep 21, 2013 2:57 pm
Sat Sep 21, 2013 3:03 pm
Lost a few of mine the third time I took the boat out. To me it seems they are a little short and the end of the bolt was barely touching the nylon in the lock nut. KP sent me some extras but I ended up going to ACE and picking up some stainless Philips head that were a 1/4" longer than the originals. Haven't had any issues since. They stay tight.
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Sat Sep 21, 2013 4:42 pm
On the real stubborn ones. I take a 1/2 brass punch and hammer and ping the nut side 6 or 7 time. Works well.
Sat Sep 21, 2013 8:46 pm
Users browsing this forum: No registered users and 29 guests
