It is currently Sun Jul 06, 2025 10:31 pm
[ 8 posts ] |
marshjunky
 Lower unit Grease?
I have a 2007 mud buddy 35 and after fishing today I found this mid way up my lower unit. Is this normal? Have I blown a seal? Thanks!
Fri Jan 31, 2014 8:19 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
 Re: Lower unit Grease?
Not normal, could be the seal behind your lower gear, pop the clutch cover off and see what ya got going on in their. Easy to replace if its a seal..could also open the plug on the bottom of your belt housing and see what comes out
Fri Jan 31, 2014 8:54 pm |
marshjunky
I opened the plug at the bottom of my belt housing and a little bit of water came out. Not a ton but enough to make a small puddle. I have to take some family out tomorrow, would it be ok to run it once more before bringing it into the shop?
Fri Jan 31, 2014 9:37 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Hard to say without knowing where the water came from.
Fri Jan 31, 2014 9:53 pm |
marshjunky
Should I tighten all of my boats down on the lower unit? I'm bringing it to gator trax this week
Fri Jan 31, 2014 9:56 pm |
270Handiman
If it's leaking through the prop seal it won't help. Just make sure they are all snug. You probably need all new seals an bearings in the lower anyway, so 1 more day shouldn't make much difference......unless it were to lock up on the water.
Fri Jan 31, 2014 10:12 pm |
marshjunky
Alright, I'm sure ill be fine. Hopefully my trip to gator trax won't cost me an arm and a leg. Thanks
Fri Jan 31, 2014 10:14 pm |
fowl habbit
I would fill it with new grease just to be on the safe side
Sat Feb 01, 2014 6:20 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 48 guests |
