It is currently Fri Jul 11, 2025 6:12 pm
Reply to topic  [ 25 posts ]
 Gator Tail Gearing Sprokets
Post Gator Tail Gearing Sprokets
Being unfamiliar with Gator Tail, and the lack of this detail on their website, I take it you can swap gearing and ratios like you can with a MB? If so, where can you buy those gears and find out more info? I did a search on here and the only thing that comes up with 'gear' is hunting gear.
Mon Feb 10, 2014 9:02 pm
Post Re: Gator Tail Gearing Sprokets
The hard part about changing gears on a gator tail is that you would have to shim the motor to accommodate the belt tension or change the top and bottom together. You also have brake caliper clearance issues to consider when you go moving the engine up to tighten the belt. Or get a new belt to match exactly.
Mon Feb 10, 2014 9:35 pm
Anyone on here done it?
Mon Feb 10, 2014 9:37 pm
They only have 2 different ratios...old one was lower new one is higher. I'm not sure if you can still get the old gear from them or not, I'm sure they have some. And the difference is the bottom gear, there's only one top.
So to answer your question, no you can't really change ratios like a MB.
Tue Feb 11, 2014 9:47 am
They still have the 45T, I bought one not too long ago to replace a worn one.
GTR, Waitin' on a DFOU hull
Tue Feb 11, 2014 3:08 pm
I run the 45 on mine
Tue Feb 11, 2014 8:54 pm
Wed Feb 12, 2014 8:09 pm
the new gear ratio is 1.263 to 1 and that's a 38 top and 48 bottom but I think I have that wrong cause it might be a 47 bottom and that would be 1.236 to 1
Wed Feb 12, 2014 8:57 pm
No it's a 48 tooth
Wed Feb 12, 2014 9:36 pm
Wed Feb 12, 2014 9:38 pm
My belt housing has 48t stamped in it
Which would mean higher geared
Wed Feb 12, 2014 9:45 pm
Wed Feb 12, 2014 9:46 pm
Yes sorry Lower is correct had a brain fart! Was editing my post but my phone rang before I could delete it and start over :lol:
Wed Feb 12, 2014 10:10 pm
Yes....the 48 is a 'shorter' gear and will increase low end pull.
Wed Feb 12, 2014 10:15 pm
Are the 45 and 48 interchangeable? Any plans of a 50?
Thu Feb 13, 2014 10:29 pm
Yes I believe you can interchange them and I can see possibly a lower gear in the future
Thu Feb 13, 2014 10:32 pm
I got this number from somewhere!! http://www.royalsupply.com/store/pc/Gat ... v4PHNqYbIU
Fri Feb 14, 2014 6:43 am
so all u have to do is change the 48 in the part number to say 50 and then u have a 50 groove pulley
Fri Feb 14, 2014 6:45 am
Have any of y'all actually changed them? Mine would require a different belt to go to a bigger gear. Not enough adjustment.
Fri Feb 14, 2014 7:44 am
From my understanding it's the same belt. And yes I know some that has played around with the 2
Fri Feb 14, 2014 8:26 am
When I talked to gator tail I was told I would have to change my belt housing. Said they make 2 lengths.
Fri Feb 14, 2014 8:28 am
Fri Feb 14, 2014 8:57 am
Fri Feb 14, 2014 9:47 am
Fri Feb 14, 2014 10:30 am
If you could find a belt that was a 1/4" longer then I think it would work.
Fri Feb 14, 2014 4:26 pm
Users browsing this forum: No registered users and 94 guests
