It is currently Sat Jul 12, 2025 10:30 pm
Reply to topic  [ 17 posts ]
 go devil longtail losing mph
Post go devil longtail losing mph
i was seeing if anyone can help me out with trying to figure out why my go devil is not as fast as it was right before duck season. It is a 20 hp go devil so its obviously not supposed to fly but 9 mph with only me and my lab...any answers?
27 gdlt/ 15x42 war eagle
Mon Jan 31, 2011 10:58 pm
Post Re: go devil longtail losing mph
check rpms and prop measurements. significant increase in rpms could mean prop wear. thats a good first step to diagnosing the issue.
17*38 Klibert 23GDLT
Mon Jan 31, 2011 11:06 pm
i appreciate it bud ill be sure to do that first thing in the morning...ignorance haunts me but would you recommend getting a tachometer to be able to check the rpms
Mon Jan 31, 2011 11:17 pm
Yup. get a TinyTach and it helps a ton!
Tue Feb 01, 2011 2:18 am
Sounds like your prop is gone!
37 EFI Prodrive pushing a 1748 Tim's Marine Custom Flat
Tue Feb 01, 2011 8:56 am
I'd highly recommend a tach. not only does it serve as a diagnostic tool but also can give you engine hours which lets you practice a good mantience schedule.
Tue Feb 01, 2011 9:25 am
Thank yall for your help its much appreciated ... Where on the Internet is the bet place to buy a tinytach
Tue Feb 01, 2011 10:34 am
As others have said, it sounds like a worn prop. Call Godevil with the serial number off the frame and order a prop and tach. Also, you can order a tach directly from the manufacturer at .... http://www.tinytach.com/tinytach/index.php
Tue Feb 01, 2011 3:46 pm
the tach has been ordered...any input on the best place to buy a go devil lt prop
Tue Feb 01, 2011 7:57 pm
buy it directly from go-devil themselves. if you go to their site, it will give you a little info on the amount the prop is gunna cost ya
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Tue Feb 01, 2011 9:06 pm
measure your prop before ordering. The diameter and pitch was originally a 9x4 most probably so see how small it is now. check your cup in the prop also. if you determine for sure you need a new prop call gd tell them your serial numbers off the motor they'll send you what you need.
Tue Feb 01, 2011 9:09 pm
Has your motor been actin weird to start?Havin to choke it any more than normal??
Tue Feb 01, 2011 9:28 pm
yeah man come to think about it some days it does act like that...any advice on whats going on
Tue Feb 01, 2011 10:22 pm
Clean your carb out, just cleaned mine out for the second time in 6 months, always getting clogged jets.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Tue Feb 01, 2011 10:31 pm
good deal bud ill be sure to do that thanks for the advise
Tue Feb 01, 2011 10:34 pm
Clean the fuel shutoff solenoid real good also
Wed Feb 02, 2011 10:05 am
If you've lost significant mph, it may be a combination of things already listed. Also maybe check the bottom of your hull. If you've been stump jumping all season you might have some dings in the rear of the hull that will slow you down aswell.
goo luck.
36 PD 1852 Brother Breaux
Wed Feb 02, 2011 12:51 pm
Users browsing this forum: No registered users and 31 guests
