It is currently Sat Jul 12, 2025 6:22 am
Reply to topic  [ 12 posts ]
 23hp vangard stalling out
Post 23hp vangard stalling out
i got a new 23hp vangard an it stalls out when im on the throttle for a good while any help on what can cause that would be appreciated thanks
Sun Nov 13, 2011 6:43 pm
Post Re: 23hp vangard stalling out
are you losing your fuel prime?
Sun Nov 13, 2011 6:49 pm
maybe a little but there is still sum gas in the inline fuel filter but not alot
Sun Nov 13, 2011 6:54 pm
pump your bulb next time and see if it starts running good again. If it does you might need a new fuel pump. I would try the bulb before you go any further
Sun Nov 13, 2011 6:55 pm
ok ill try that so by fuel pump do u mean i will need a new primer bulb?
Sun Nov 13, 2011 7:04 pm
follow your gas line until it runs into something like this
http://tewarehouse.com/7-08024?sc=2&category=30
your fuel pump should be similar.
Sun Nov 13, 2011 7:27 pm
Sounds like an air leak in your fuel line, bad pump, or trash in the carb. Probably air or trash though.
Sun Nov 13, 2011 7:55 pm
ok cool ill try an track it down thanks for the help guys i appreciate it
Mon Nov 14, 2011 5:00 pm
i took it back out today an it done it agin, i had allready went through an checked my gas line it seems to be fine, an its a brand new motor i have only had it out 6 times, but once i squeezed the primer bulb it would fire right up, but a lil bit after it would die out agin?
Sat Nov 26, 2011 10:23 am
Gething air in the fuel line somewhere check all hose clamps
Sat Nov 26, 2011 1:04 pm
New Member
This has happened to me before and I did the same thing as far as checking all the possible gas problems. What it ended up being for me was the oil level. Apparently I had too much oil in the motor, and after running for a while, the oil level would rise and cause the motor to bogg down. Maybe try taking out a little oil and see if that helps.
Tue Nov 29, 2011 2:35 pm
My Vanguard 23 did the same thing to me when I first bought it and I could not figure out what was wrong. It was under warranty so I took it to the local service provider and he said there was some "trash" in the carb and he flushed the carb and it has ran like a champ ever since.
Fri Dec 02, 2011 9:20 pm
Users browsing this forum: No registered users and 62 guests
