It is currently Sun Jun 29, 2025 7:48 am
Reply to topic  [ 11 posts ]
 Motor swap
Post Motor swap
Could i swap motors on a 9 hp longtail to like a 13 harbor freight on the same frame?
Fri Jan 24, 2014 1:58 pm
Post Re: Motor swap
If the motor lines up sure. Don't know if you are concerned about the frame holding up due to the hp difference. Should be fine
23 swomp/ 1542 tracker
Fri Jan 24, 2014 2:08 pm
Post Re: Motor swap
So really if everything lines up and strength of frame/ motor plate is fine then I should be good
Fri Jan 24, 2014 2:31 pm
Post Re: Motor swap
Yep
Fri Jan 24, 2014 2:33 pm
Post Re: Motor swap
10-4 Preciate it trout
Fri Jan 24, 2014 2:35 pm
Post Re: Motor swap
Yes , should be the same up to 16 hp , I have swapped before from 9-16. .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Fri Jan 24, 2014 4:00 pm
Post Re: Motor swap
I swapped an 11 Honda for a 13 Honda on devil. Called go devil first though.
1548 weldbuilt 13 hp GD Crawfish
Thu Mar 06, 2014 8:35 pm
Post Re: Motor swap
23 hp go devil long tail. 12 hrs. Wanting to swap for 35 or possibly bigger surface drive with under 125 hrs
Call me if interested. 678-346-5689
Thanks
Mon Mar 17, 2014 9:34 am
Post Re: Motor swap
Thanks
Post Re: Motor swap
Thanks
Mon Mar 17, 2014 9:36 am
Post Re: Motor swap
mine is a 27hp kohler. not 23. see above messages for everything else. thanks
Wed Mar 19, 2014 6:53 pm
Users browsing this forum: No registered users and 43 guests
