It is currently Tue Jul 15, 2025 6:38 am
Reply to topic  [ 10 posts ]
 shaft removal
Post shaft removal
I have a 25 hp godevil longtail and need some advice on pulling the shaft out in order to change the upper seals. i'v tried sliding a 1" thick piece of solid steel over the shaft, followed by 2 jam nuts, unscrewing the lower seal cap (essentially a shaft puller), and hitting the yoke with a hammer. unfortunately this isn't working. i've put so much pressure on the lower seal cap that the threads are begining to roll. I'v also tried moderate heat at the key stock, but to no avail. I have removed the set screws, and the only resistance that is keeping the shaft in place is the key at the u-joint.
can anyone give me some pointers?
thanks,
mm
Sun Dec 13, 2009 9:53 am
Post Re: shaft removal
When I had mine done at the go devil dealer the guy had a slide hammer that threaded on to the end of the shaft where the prop goes. That worked in about 3 seconds.
Sun Dec 13, 2009 5:06 pm
Before you phucked up the threads you could've taken the prop nuts, prop, and forward jam nut off, slid on a piece of pipe, and then tightened one of the nuts with a washer to pull the shaft out. On second thought, it should work if you tighten the collar all the way up cause it will just push the collar against the shaft.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Dec 13, 2009 6:50 pm
You can rent a slide hammer/axle puller kit (I think that's what they called it) from auto zone for free. Thats what I used, worked like a champ.
Sun Dec 13, 2009 8:27 pm
Sun Dec 13, 2009 9:15 pm
Sun Dec 13, 2009 10:06 pm
gotcha!!!!
Mon Dec 14, 2009 8:02 am
Mon Dec 14, 2009 6:30 pm
well i may be an ignorant newby, but i'm thick skinned enough to read through the smart assidness advice and comprehend what you're telling me. Don't swear off helping all newbies. that's one component that leads to good threads and makes this a fun place to lurk. thanks for your help and i'll let you know how it turns out.
mm
Mon Dec 14, 2009 10:05 pm
Whatever you do DONT TRY AND USE THE CAP AS A PULLER!! YOul phuck ur threads real fast... i built a slide hammer for mine with some pipe and a couple nuts and worked like a charm. 8-)
ETD88 09/28/09-05/14/2010...
Tue Dec 29, 2009 1:25 pm
Users browsing this forum: Majestic-12 [Bot] and 42 guests
