tjbraves02
 Grease piston-go devil
I have a 16 hp long tail go devil, and I am curious if anyone else has had this problem. The grease in the grease piston is leaking around the plunger within the piston, not a big deal, but it is annoying. It was brand new last winter this is the first year I've hunted with it. It has been this way since I got it almost. Thanks for your help.
Thu Nov 13, 2014 1:20 pm |
butternut
Joined: Tue Nov 12, 2013 9:30 am Posts: 770 Location: EAST ARKANSAS
 Re: Grease piston-go devil
May need to rebuild it.
Thu Nov 13, 2014 1:26 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
Those aren't very expensive and if you don't buy one from Go-Devil, you can get one from McMaster-Carr.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
Thu Nov 13, 2014 2:51 pm |
kibb
Do you fill the lubricator full when servicing the motor? You are only supposed to fill it 3/4 to give room for expansion. The grease may be seeping past the side of the position when the pressure builds up. It's simple to tear apart and clean if this is the case.
Thu Nov 13, 2014 6:22 pm |
StevefromAR
Just don't drop it on the concrete! Cause it will break! I bought my replacement on eBay for less than $20. But they were about $40 everywhere else. Local farm supply would be a good place to check.
Wed Dec 03, 2014 8:06 pm |
Bayport
I didn't think u were supposed to fill that piston. You fill form the 2 lower fittings until the piston goes to full. But maybe I'm wrong
Thu Dec 18, 2014 7:02 pm |
kibb
^that's correct. I failed to mention that
Thu Dec 18, 2014 8:07 pm |
Kcpanages
Or u can put a plug in it like MBLT has. O pull the plug and pump mine full from the bottom till is comes out of plug in middle section of shaft
Sun Dec 21, 2014 1:25 pm |
bigticket
Joined: Thu Jan 09, 2014 11:40 pm Posts: 94 Location: somewhere fishing
My gdlt 16 did the same thing,I have the go devil lubricator on it, what I did was take the top off it and clean it all out after I got it back together I didn't add grease but run it and the grease in the tube filled it back up on its own once it heated up Prob went up 3/4,problem was it was just over full and bypassing the piston from the pressure,I always take my grease gun just in case tho.
_________________ 1654 GDSD 37efi.
Sun Dec 21, 2014 8:31 pm |
Kcpanages
Sun Dec 21, 2014 9:35 pm |
