It is currently Sun Dec 21, 2025 11:32 am
Reply to topic  [ 10 posts ]
 Grease piston-go devil
Post Grease piston-go devil
I have a 16 hp long tail go devil, and I am curious if anyone else has had this problem. The grease in the grease piston is leaking around the plunger within the piston, not a big deal, but it is annoying. It was brand new last winter this is the first year I've hunted with it. It has been this way since I got it almost. Thanks for your help.
Thu Nov 13, 2014 1:20 pm
Post Re: Grease piston-go devil
May need to rebuild it.
Thu Nov 13, 2014 1:26 pm
Those aren't very expensive and if you don't buy one from Go-Devil, you can get one from McMaster-Carr.
Thu Nov 13, 2014 2:51 pm
Do you fill the lubricator full when servicing the motor? You are only supposed to fill it 3/4 to give room for expansion. The grease may be seeping past the side of the position when the pressure builds up. It's simple to tear apart and clean if this is the case.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Nov 13, 2014 6:22 pm
Just don't drop it on the concrete! Cause it will break! I bought my replacement on eBay for less than $20. But they were about $40 everywhere else. Local farm supply would be a good place to check.
Wed Dec 03, 2014 8:06 pm
I didn't think u were supposed to fill that piston. You fill form the 2 lower fittings until the piston goes to full.
But maybe I'm wrong
Thu Dec 18, 2014 7:02 pm
^that's correct. I failed to mention that
Thu Dec 18, 2014 8:07 pm
Or u can put a plug in it like MBLT has. O pull the plug and pump mine full from the bottom till is comes out of plug in middle section of shaft
Sun Dec 21, 2014 1:25 pm
My gdlt 16 did the same thing,I have the go devil lubricator on it, what I did was take the top off it and clean it all out after I got it back together I didn't add grease but run it and the grease in the tube filled it back up on its own once it heated up
Prob went up 3/4,problem was it was just over full and bypassing the piston from the pressure,I always take my grease gun just in case tho.
1654 GDSD 37efi.
Sun Dec 21, 2014 8:31 pm
Sun Dec 21, 2014 9:35 pm
