It is currently Sat Jul 12, 2025 11:02 pm
Reply to topic  [ 12 posts ]
 16 HP home build question
Post 16 HP home build question
Hey guys I planned on making a 6.5 hp home build but ran across a 16 hp horizontal shaft for 150 bucks so i snapped it up. Now im having second thoughts. I over looked the fact that it was a IC and not a v-twin. My question is does it matter? Will this motor work for making a long tail? Im afraid that there is going to be too much vibration. Let me know what you think.
Thanks,
Bobby
Fri Jun 24, 2011 7:20 pm
Post Re: 16 HP home build question
The 16 isnt a v-twin?
Fri Jun 24, 2011 7:28 pm
I dont see why it wouldn't work.
Fri Jun 24, 2011 7:50 pm
It is a used motor out of a mid 90's craftsman mower. Its a 16 hp IC which i thought meant Inline cylender but i could be wrong. This wont cause too much vibration will it?
Fri Jun 24, 2011 7:56 pm
As long as its a horiz. shaft I dont see what the problem is. Is it a tapered crank? Or straight? Straight you should be able to get a 1in. yoke and be all set.
Fri Jun 24, 2011 9:04 pm
As for vibration define too much.I have no idea what the IC stands for either.
Fri Jun 24, 2011 9:06 pm
Industrial/commercial engine. They usually have cast iron sleeves and heavy duty air filters & valves.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Jun 24, 2011 9:20 pm
I have a 16 hp duromax engine from maxtools.com it is a single cylinder motor and it runs fine no more vibration then a honda single cylinder engine i upgraded to it from my 9 hp cause it was such a good deal only like $330 brand new couldnt past it up i can buy 3 of those for the price of one vanguard so far its a great little longtail engine hope this helps
Fri Jun 24, 2011 9:29 pm
1436 Lowe
Sat Jun 25, 2011 12:28 am
Thanks for the input guys. I'm gonna give it a run with this one and if it doesn't work I'll have the frame built and might try one of the durostar ones
Sat Jun 25, 2011 6:10 pm
Alright guys i got the motor running and my next investment is the prop. I mainly run in shallow rivers and in beaver ponds with lots of logs and weeds. My question is what size prop do i need. I was looking at Hill Marinebut im open to other suggestions too. Any help is appreciated guys.
Thanks,
Bobby
Thu Jun 30, 2011 8:20 pm
Go with the hill, I built 3 so far this month and of the different props we have bought the hill seems to be exactly what I should have bought. Also cheaper than what I paid from ebay.As for the prop size just tell them what size motor you have. For reference, the mudbuddy I used for a pattern was a 13hp with a gear reduction used a 10x10 prop.
Fri Jul 01, 2011 5:46 am
Users browsing this forum: No registered users and 38 guests
