It is currently Tue Jul 15, 2025 11:16 am
Reply to topic  [ 6 posts ]
 6-9hp LT Owners got a?
Post 6-9hp LT Owners got a?
Does your motor vibrate like hell when about half throttle or so? I just put a new motor and all on mine along with new U joints and yokes. Before I did this it vibrated a little but now man it's bad!!!! Once the motor is wide open it plains out but damn when it's at half throttle it feel like it's running a jack hammer.
The original yoke (that went from motor to the u joint) that was on this motor had two set screws the new one only has one set screw I'm thinking that this is the reason why it is so bad! Should I try to balance the yoke out or something?
O yeah and this is a GD motor to not a home made rig.
Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Wed Jul 06, 2011 12:06 pm
Post Re: 6-9hp LT Owners got a?
yep. just run it wide open and be done with it :D
Wed Jul 06, 2011 2:07 pm
mine is home made and like your's it vibrates pretty bad until about 3/4 throttle. Thats why I run it wide ass open.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Wed Jul 06, 2011 2:55 pm
could be bent shaft or unbalanced prop but if its like my 9hp lifan clone. it vibrates at just above idle. but i think it has to do more with the single cylinder slinging sidways. my 16 vanguard runs like a cadillac compared.
Wed Jul 06, 2011 7:35 pm
i had a 11hp tecumseh w/ vertical cylinder that vibrated at 3/4, the new greyhound 11hp w/ slanted cylinder runs MUCH smoother. course im sure thats mostly cause the greyhound has overhead valves where the tecumseh didnt...
-1436 flatbottom
Thu Jul 07, 2011 8:16 pm
Fri Jul 08, 2011 7:26 am
Users browsing this forum: No registered users and 40 guests
