It is currently Tue Jul 15, 2025 5:28 pm
Reply to topic  [ 6 posts ]
 6-9hp LT Owners got a?
Post 6-9hp LT Owners got a?
Does your motor vibrate like hell when about half throttle or so? I just put a new motor and all on mine along with new U joints and yokes. Before I did this it vibrated a little but now man it's bad!!!! Once the motor is wide open it plains out but damn when it's at half throttle it feel like it's running a jack hammer.
The original yoke (that went from motor to the u joint) that was on this motor had two set screws the new one only has one set screw I'm thinking that this is the reason why it is so bad! Should I try to balance the yoke out or something?
O yeah and this is a GD motor to not a home made rig.
Wed Jul 06, 2011 12:06 pm
Post Re: 6-9hp LT Owners got a?
yep. just run it wide open and be done with it :D
Wed Jul 06, 2011 2:07 pm
mine is home made and like your's it vibrates pretty bad until about 3/4 throttle. Thats why I run it wide ass open.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Wed Jul 06, 2011 2:55 pm
could be bent shaft or unbalanced prop but if its like my 9hp lifan clone. it vibrates at just above idle. but i think it has to do more with the single cylinder slinging sidways. my 16 vanguard runs like a cadillac compared.
Wed Jul 06, 2011 7:35 pm
i had a 11hp tecumseh w/ vertical cylinder that vibrated at 3/4, the new greyhound 11hp w/ slanted cylinder runs MUCH smoother. course im sure thats mostly cause the greyhound has overhead valves where the tecumseh didnt...
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Thu Jul 07, 2011 8:16 pm
Fri Jul 08, 2011 7:26 am
Users browsing this forum: No registered users and 55 guests
