It is currently Fri Jul 11, 2025 8:12 pm
Reply to topic  [ 5 posts ]
 Lubrication and Bushings for Lt shaft?
Post Lubrication and Bushings for Lt shaft?
Starting on my first LT build and I am confused as to whether or not the shaft housing is filled with oil, or the shaft just lubricated with greasable bushings/bearings. I have been looking through the forums for answers to alot of questions about this build, and have found alot of useful info.
Thanks for any help.
Burner
Fri Nov 04, 2011 1:57 pm
Post Re: Lubrication and Bushings for Lt shaft?
just grease for the lontail. Well except for the motor of course.
17*38 Klibert 23GDLT
Fri Nov 04, 2011 2:01 pm
Thanks go gogetter! i had read another persons build, and he filled his shaft housing with 50wt... Didn't seem right to me, but i figured I'd ask.
Fri Nov 04, 2011 2:44 pm
Most people just use grease, but gear oil works great too. If you run where the temps are well below freezing, you'll definitely appreciate gear oil over grease when you try to start it in the mornings. I know I've had to warm my tube with a propane torch more than once to be able to pull it when the temps are bitter.
Fri Nov 04, 2011 10:30 pm
I am running Mobil 1 synthetic grease in my mine. I am going to try one of those electric cords you wrap around outside pipes to keep them from freezing on my shaft housing if it gets too cold.
Wed Nov 09, 2011 12:35 pm
Users browsing this forum: No registered users and 62 guests
