It is currently Sun Jun 29, 2025 8:14 am
Reply to topic  [ 13 posts ]
 Mad mud motor plans
Post Mad mud motor plans
Just ordered the mad mud motor plans using a kohler courage 6.5 for the motor anyone have any experience with the mad mud motor plans or any advice this will be my first build so any advice would be great
Thanks
Tue Nov 27, 2012 7:04 pm
Post Re: Mad mud motor plans
What type of welder will u be using ie stick or mig either way u want to stagger your heat , espacially where all 3 braces meet if you weld them all at once ( keep your heat in that area) you may deform the dom tubing if that what u r going to use . Hope this helps
Tue Nov 27, 2012 9:31 pm
i'm going to create a new drinking game
Every time someone asks about the 'mad mud motor plans'
B. MacDonald
Wed Nov 28, 2012 11:20 am
Mig welder and thanks what angle should the shaft be at I heard straighter the better I am also going to be shortening the handle because the stealth 1200 doesn't allow for much moving around with the longer handle
Wed Nov 28, 2012 3:48 pm
I not sure for your boat but mine and a friend that i built where set at 15 degrees his reuns great very happy with it mine still havent had it in the water boat problems and the lakes our starting to freeze around here
Wed Nov 28, 2012 6:23 pm
Just finished building my 4 one.
Wed Nov 28, 2012 7:32 pm
15* shaft angle works pretty well on most boats, any steeper and your pushing the limits of the u-joint for longevity and vibration, any shallower and the prop might not ride right. Shallower angles on a short transom boat will be faster though, more of the thrust is pushing you forward
Mon Dec 03, 2012 8:45 am
Nice looking motor!
mudslinger - Missouri
Homemade 13' layout boat
Homemade 6.5 hp Long tail Mud Motor
The second amendment is what makes the first amendment possible...
Sun Jul 28, 2013 12:35 pm
I just got my plans from MMM and I am really less than impressed. Most people have watched the 8 part MMM build video on YouTube and the plans don't have much more information. All the 'hard to find' parts are listed on McMaster Carr website (just do a search with your sizes). No specifics on larger engines, etc. I emailed in one question on 'thrust to the motor shaft' and got the standard answer 'we made it as simple as we could'. Since the pictures in the plans are not good, I now wish I would have gotten the CAD version that are sold right next to MMM on EBay. Maybe there would have been some new information in those.
Tue Jul 30, 2013 8:26 am
I bought the MMM Plans also and ended up only using small parts of the book for the actual build. Some of my own personal upgrades were tubes for the frame, Hill Marine Prop, Beavertail bearing assy and prop shaft. Their transom mount is also pretty cheesy so I used a T design I seen on someone elses build. You could get just as much info off Youtube and here on the forum. Your imagination is your only limitation. Good Luck Builders.
Also thought the plans lacked substance but it does give you a good starting point.
Tue Aug 27, 2013 12:14 am
I have seen several motors built using the plans and they work great!
Sat Nov 02, 2013 7:30 pm
I ordered a surface drive motor plan from ebay and they look great
25 yamaha pushing a 1642 welded flat
20 hp go-devil longtail for hunting
Sat Nov 02, 2013 10:13 pm
23 swomp/ 1542 tracker
Sun Nov 03, 2013 11:26 am
Users browsing this forum: Majestic-12 [Bot] and 50 guests
